04-23-2015, 03:53 PM | #1 |
64 C10 dash & gauges
My 64 c10 gages are all idiot lights and I would like to have real gauges. I have seen some complete dash panels with speedo, gauges etc. What years look and fit like 1964? How much trouble is it to replace? thanks
04-23-2015, 04:27 PM | #2 |
Re: 64 C10 dash & gauges
64-66 clusters would be the only year clusters that will fit the dash. There are quite a few modifications needed to make it work with the existing harness.
The oil line is the simple -The sending unit is removed and a line is plumbed into the gauge. The fuel gauge and speedo are the same. The ammeter has to be wired in as does the temp gauge. Most opt for replacement harness designed for the factory gauges, but it can be done with a warning light harness if you make the correct modifications.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
04-23-2015, 09:10 PM | #3 |
One foot in front of the other
