Old 04-23-2015, 06:31 PM   #51
slomotion
Old Duffer
slomotion's Avatar
Re: Stumped by a timing problem
Thank you Mechanicalman.
Let me add one more item to look at.....if your distributor goes south again, pull it out, push the lock pin out of the drive gear, pull the gear off and replace your thrust washer on the distributor shaft. When the engine is running, your cam gear is trying to push the dist. shaft up because of the angle of the gear teeth. At lower RPM, it may not be noticeable, but at higher RPM the rotor may be striking the cap.
'68 Short C20 Flatbed Dually
w/ 292 4bbl, Langdon cast headers,
and WC T5 trans.
'81 G10 Shorty Van
"Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers
"Under promise, then over achieve."
slomotion is offline   Reply With Quote
Old 04-24-2015, 01:25 AM   #52
tranz am
tranz am's Avatar
Originally Posted by MAC71 View Post
After the cap replacement the backfire is gone but it has a lean surge now but that's a jet change.
So before the rebuild with the points it had to have been the timing chain but the bad distributor cap looks to be the problem after the rebuild.
Thank you all for the help I would have never thought the cap
Glad to help with this. Sometimes its the small simple things that we just didnt think about.
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=456220
Best 1/4 mile time 12.1 @ 111 w/traction issues
1969 GMC SWB
1964 chevy II Nova ht
tranz am is offline   Reply With Quote
Old 04-24-2015, 04:38 AM   #53
Norgermish
Norgermish's Avatar
It has been mentioned already but, I remember building a 396 for a lake boat. It ran great at Nacimiento Lake here in central ca. then he moved to Lake Tahoe and it ran like crap...it was the altitude
Norgermish is offline   Reply With Quote
