Old 04-27-2015, 02:36 PM   #1
bbcmudtruck
Prop valve lines
I've spent quite a while searching and haven't been able to come up with the answer here. I'm relocating my prop valve to under the cab along side the frame so I can hide the brake lines a little better. I know that the front two valves are for the front, left/right. My question is does it matter which side of the truck the lines go to, as long as I'm using the front valves? I believe from the factory, the top mount was routed to the passenger side brake. I want to switch mine around and run the top valve to the driver side and the bottom valve to the passenger. Is there any reason that won't work?
bbcmudtruck is offline   Reply With Quote
