04-27-2015, 04:08 PM | #1 |
2 or 4 bolt main?
is there a way to tell if i have a 2 or 4 bolt main 400 small block without droping the pan? casting number 3851511 and if anybody could give me some more info on this that would be great
04-27-2015, 04:16 PM | #2 |
Re: 2 or 4 bolt main?
CHECKED ONLINE AND 4 BOLT IF THREE FREEZE PLUGS AND 2 IF TWO FREEZE PLUGS
http://outintheshop.com/faq/casting/castings2.html |
04-27-2015, 04:24 PM | #3 | |
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
04-27-2015, 04:26 PM | #4 |
I believe all 400s have three freeze plugs or at least the boss for the third one. I don't think you can tell without dropping the pan. Jason
04-27-2015, 04:44 PM | #5 |
no big difference one way or the other
way overrated
04-27-2015, 04:46 PM | #6 |
1970 was the only year for 4-bolt mains 400 SBC.
Tony Nicholas @ Midwest Metal Masters 1953 Chevy 3100 392 Hemi w/727 & 9” Ford 1985 Chevy C/10 6.0L 4L80 373 locker |
04-27-2015, 04:57 PM | #7 |
Justin, is that the number on the back of the block? I used silly putty to press into it to get an imprint of the number?
It's located on the driver's side down by the bell housing. That's on a 350 though, not sure about the 400. |
04-27-2015, 06:08 PM | #8 |
I'm pretty sure that all 400's were three freeze plug motors. Dropping the pan is the only way I think. I didn't know that the 400 was made as early as 70 though. I do remember when GM sent out a statement to all dealers saying they were discontinuing the parts replacement short blocks and they had a limited number of them the price I could have bought a short block for was about $400 to $450. That was late in the 80's. Jim
04-27-2015, 06:09 PM | #9 |
thats the number on the driver side back of the block infront of the bell housing. the date number is D 3 72.
pic 1: block casting number 3951511 pic 2: block date number D 3 72 pic 3: ID number on the right. its located on the passenger side inform of the head number T04L9CKB. pic 4: id number on the left of the number from pic 3 number 12Y140503. i talked to a guy who had a 68 stepside he has a book with casting number ids and such. he told me it was a 4 bolt main and that 70-72 was 4 bolt 73 was only 2 bolt. EDIT: if you look to the right of picture 2 it looks as if the block casting number is on the other side as well but upside down. I'm not home at the moment so i can't wire brush it to find out. |
04-27-2015, 07:44 PM | #10 |
I just checked with my old engine builder about our days building 400s. He corrected me and said the 4-bolt main blocks are 1970-1972 only. 1973-1980 were all 2-bolts. The 1970 was the only year with any compression. After that, they were all 8:1 motors.
04-27-2015, 08:04 PM | #11 |
x2
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
04-27-2015, 08:21 PM | #12 |
3951511= 400cid, Car & Truck, 2 & 4-Bolt main, 3-freeze plugs
D 3 72 Block casting code D=April 3=3rd 72=1972 T04L9CKB Engine id stamp=plant/assembly date/application code T=Towanda 04=April L9=19=19th CKB=Chevelle/Impala 350cid, 165hp, 350trans, 2bbl BUT CKP=Impala, 400cid, 170hp, 400trans, 2bbl Rochester Check the last digit again. I think that's a P not a B 12Y140503 1=Chevrolet 2=1972 Y= Wilmington assembly plant 140503=Build sequence number Your engine is a 1972, 400 out of a Impala. EDIT: 1970 to 1972 400s were all 4 bolt mains as 65standard stated in post 10. Your block is a 4 bolt main..
CHEVY/GMC VIN DECODERS Last edited by bruceman1968; 04-27-2015 at 08:53 PM. |
04-27-2015, 11:46 PM | #13 |
Like cdowns said. Factory 4-bolt is way over-rated so don't fret it too much. In fact, some racers actually prefer the two bolt blocks. Far as freeze plugs go. I have seen sb 400's with three plugs per side, two plugs per side with center cast bosses not drilled for plugs, and some which had no center cast bosses at all. Those are usually early '70 blocks and said to be the strongest.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed. |
04-29-2015, 12:53 AM | #14 |
How did I get this OLD!
I had 2-400sbc 3951511 blocks with 72 cast dates. Both sold as 4 bolt, both had 3 frost plugs, dropped the pan both 2 bolt. http://67-72chevytrucks.com/vboard/a...1&d=1430283047
I had the engine builder machine the block for Eagle splayed main caps. |
04-30-2015, 07:03 PM | #15 | |
thanks everybody for the help, i really didn't want to lift the engine to drop the pan just to see if it has 2 or 4 bolts lol Last edited by justin4260; 04-30-2015 at 07:10 PM. |
04-30-2015, 07:22 PM | #16 |
Dropping the pan is the only way to be 100% certain. Why does it matter? Selling the engine?
04-30-2015, 07:27 PM | #17 |
wanted to make sure the bottom end can handle boost before i start investing in new headers and heads and superchargers or turbos. if it is a 2 bolt main i might sell it but most likely i will just put good heads on it and not boost it and then get a different truck or car to do boost on.
04-30-2015, 07:34 PM | #18 |
Justin you may still have to drop the pan. If the 2 engines that canuckvetter is talking about in post 14 were built in the first half of 72, then you'll have to drop the pan to be sure. But if they were cast later in the year then stick with 4 bolt. Need to find out the month codes of his 2 engines. Real life always trumps the book. Here is a pic of the table I used to answer your question.
CHEVY/GMC VIN DECODERS |
04-30-2015, 07:39 PM | #19 | |
04-30-2015, 07:43 PM | #20 | |
04-30-2015, 07:51 PM | #21 |
what is the significance to the 4 bolt vs the 2 bolt and vise versa?
04-30-2015, 10:00 PM | #22 |
The two bolt main caps are stronger
1978 Dodge Omni |
04-30-2015, 10:26 PM | #23 |
Cruzin
I agree, overrated. My dad always said he wouldn't turn around for the difference. He ran two bolt engines in his dirt track cars didn't worry about It, he said the rods would probably go first.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
05-04-2015, 05:56 PM | #24 |
ok some guys are saying 2 bolts stronger some guys say 4 bolts stronger some say it don't matter. i think its personal preference and application then.
