Stock shocks?
Hello,
I am putting a 1" drop on the front and 3" on the rear. Just got the springs delivered and will be putting them in this weekend. My question is do I use the stock shock lengths or does that require special shocks? I get conflicting info when I search. LMC says I don't but Brothers says yes. Thank you for the help. whoops... forgot to mention it's a '69 C10 2wd. I am putting an aluminum LS in. Keeping drum brakes (for now) Last edited by danpomeroy; 04-30-2015 at 12:54 PM. Reason: forgot specs. |
Wide n'Low
![]() Join Date: Jan 2007
Re: Stock shocks?
Should be in one or more of these threads, i had them saved for this same reason
http://67-72chevytrucks.com/vboard/s...d.php?t=573266 http://67-72chevytrucks.com/vboard/s...d.php?t=268817 http://67-72chevytrucks.com/vboard/s...d.php?t=335035 http://67-72chevytrucks.com/vboard/s...d.php?t=330493 http://67-72chevytrucks.com/vboard/s...d.php?t=410506 http://67-72chevytrucks.com/vboard/s...d.php?t=330493
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
Re: Stock shocks?
No for the fronts.
Relocated rear mounts will help keep geometry & travel like stock.
Re: Stock shocks?
Thank you for the info.
If I relocate the rears can I use stock? |
Re: Stock shocks?
Yes. That's one of the benefits of relocated stock/aftermarket brackets. You utilize off the shelf replacement shocks designed/spec'd for a C10.
Re: Stock shocks?
Thank you Guys. I just ordered my shocks.
