Old 05-01-2015, 09:15 AM   #1
Longhornss
Dimmer Switch Relocare
Has anyone relocated the High beam dimmer switch from the floor?
I have some toe/floor pan rot, I am doing a dynacorn floor pan as lots of the floor braces are rotted away and I feel it will be a cleaner finished product instead of patching in sections of floor and braces.
so while I am there I figured I would remake the flange that welds the toe pan and floor seam together.
If i relocate the Dimmer I wont have to worry about having to form the pocket for the switch to fit in.
So if anyone has done a relocate where did you put them?
Longhornss is offline   Reply With Quote
Old 05-01-2015, 07:40 PM   #2
1968aj
Re: Dimmer Switch Relocare
on one truck I had I just moved it up a couple of inches and drilled a new hole . had no problems with it
1968aj is offline   Reply With Quote
