Old 02-08-2004, 07:47 PM   #1
72MARIO
72MARIO's Avatar
Would this work ?
I picked up a Van tilt coloum. It had a factory curise controll switch in the turn signal lever. Could I use that switch to controll the lock-up ? If I was to run the 12 volts thru the cruise switch ? I only want to be able to lock and unlock the torque converter. I think it would. Any reason it would not ?
Thanks .
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 02-08-2004, 09:45 PM   #2
JimKshortstep4x4
Talking
Since the control wires are so small, I would use a relay in the system so that the relay carried the load of the lockup and not the small wires in the cruise control.
Jim
Old 02-08-2004, 09:52 PM   #3
FirstGen
Just Don't Stop!
FirstGen's Avatar
exactly what I was going to say, use a relay from Radio Shack and it should work no problem. The only question then would be if it is a momentary switch or a toggle type swith on the coloum.
1968 C10 build in process
TT LSA/6L90e/9"
FirstGen is offline   Reply With Quote
