Old 05-01-2015, 02:45 PM   #1
wario26
Power Brake Swap Question..
Hi All,
I have a 1970 C-10 SWB 4x4 and want to see what you guys think of a power brake swap that I want to do. I bought both axles from a 1974 blazer and are in great condition. I have a friend that will sell me the whole brake system off of a 2003 suburban for $100 bucks it includes everything from booster to pedal to brake lines. How hard if any will it be to do this swap the whole brake system. Let me know. Thanks.
wario26 is offline   Reply With Quote
Old 05-01-2015, 04:04 PM   #2
hugger6933
Re: Power Brake Swap Question..
That should be a hydro boost brake booster, you'll need a power steering pump for that in case you dont have power steering.
hugger6933 is offline   Reply With Quote
Old 05-01-2015, 07:36 PM   #3
wario26
i already have a steering pump but i'm kinda lost what would the function of the steering pump have to do with the brakes?
Old 05-01-2015, 07:47 PM   #4
EARNHARDT#3
EARNHARDT#3's Avatar
If it's hydroboost (which I doubt the suburban is unless maybe a 2500) it uses hydraulic pressure from the PS pump instead of a vacuum source like on traditional power brake setups.
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP
EARNHARDT#3 is offline   Reply With Quote
Old 05-01-2015, 10:32 PM   #5
wario26
I doubt it also, i looked around last time i went and i can remember that it had a hose most likely the vacuum hose connected to the intake, but not to the power steering.
Old 05-01-2015, 10:34 PM   #6
wario26
Will i have to do anything in particular to make the swap work? I am also going to swap the engine. (5.3)
Old 05-01-2015, 10:44 PM   #7
hugger6933
I currently have two HALF ton Suburbans on my yard right now a 2002 and a 2004 and the both have hydroboost systems. So I am not posting out of turn when I say it could have a hydro boost system. I also have a 2002 three quarter Suburban and it also has the hydro boost but that is not crazy cause the 3/4 tons I've junked had the same set up I have like five of those.
Old 05-01-2015, 11:22 PM   #8
wario26
I guess the good thing is that regardLess if it does or not i have power steering. Thanks for the input i'll look closely just to be on the safe side..
power brake swap
