Old 05-01-2015, 07:26 PM   #1
1968aj
A longhorn showed up today
Bought me a longhorn. it showed up today. it is a Cheyenne super big block. best optioned truck I ever had and I have owned several. this truck belonged to another member of this forum .don't know his name but I was hoping he sees this and gives me more history on the truck. maybe even tell me about any problems to expect. seems like a good unmolested truck . anyway I am very pleased with it. got rid of all my other trucks except my 69 swb cst which I will post pictures of soon.
1968aj is offline   Reply With Quote
Old 05-01-2015, 07:29 PM   #2
skrenly
skrenly's Avatar
Re: A longhorn showed up today
Very Neat truck!
Great find.
skrenly is offline   Reply With Quote
Old 05-01-2015, 10:09 PM   #3
Ozark Tim
Ozark Tim's Avatar
What Steve said!
Ozark Tim is offline   Reply With Quote
Old 05-01-2015, 10:13 PM   #4
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Boom!
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 05-01-2015, 10:18 PM   #5
In The Ten Ring
I love these Longhorns......especially the ones with the extra fuel tanks and upper & lower side trim.
The longer beds are somehow "more balanced" to me and you can haul longer materials.
In The Ten Ring is offline   Reply With Quote
Old 05-02-2015, 01:23 AM   #6
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Looks like a beauty, where/how did you find it.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 05-02-2015, 09:46 AM   #7
HSRACER
HSRACER's Avatar
Nice find AJ! You are suppose to call me when these things come available!
HSRACER
Slammed 53 5 window
Blown/Bagged 54 Pickup
Patinaed 67 LS stepside
Supercharged 67 Nova
Bagged 69 Suburban Turbo'ed 5.3 LS
HSRACER is offline   Reply With Quote
Old 05-02-2015, 09:47 AM   #8
toms68cst
toms68cst's Avatar
Wow. That's a beauty.
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles.
TREASURER, Drum Brake Club.
toms68cst is offline   Reply With Quote
Old 05-02-2015, 09:51 AM   #9
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Nice, very nice
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 05-02-2015, 11:24 AM   #10
Primo Longhorn
Old 05-02-2015, 11:59 AM   #11
factorystock
factorystock's Avatar
Very clean, looks like the original paint can still be brought back to life. Ex. camper haulers usually require the least amount of work.
factorystock is offline   Reply With Quote
Old 05-02-2015, 10:10 PM   #12
1968aj
yeah but this ones a keeper
Old 05-03-2015, 10:52 AM   #13
1968aj
found it on Lubbock Texas craigslist. bought it sight unseen and had it shipped to me. I know one previous owner is a member here. maybe he will chime in and tell me more about it.
Old 05-08-2015, 09:20 PM   #14
1968aj
trying to figure what gear ratio this truck is. between 50 to 60 mph this motor sounds like im doing 80 mph. what would be involved in changing to a more of a highway gear? are parts even available? going to give it a tune up this weekend and maybe change it to hei distributor . I cleaned and shined it up this week and it shines good except the top of bedsides.
Old 05-08-2015, 09:55 PM   #15
Already Gone
Your truck should have a 3:54 unless it was switched out somewhere along the line. If it had a 4:10 from the factory it'd show on the spid.
Old 05-08-2015, 10:04 PM   #16
1968aj
had a 72 z28 that was changed to 4-10 this truck seems geared higher than that. can I just change the gears in this rear end?
Old 05-09-2015, 08:36 AM   #17
WIDESIDE72
WIDESIDE72's Avatar
Nice truck! 4.10s in a camaro ill have a lower "effective" ratio than they would in your truck, due to the height of the tires. The taller tires will effect the first all drive ratio. I believe the 72 c20s have a dana 60 (?) If so, a variety of gear ratios is available.
WIDESIDE72 is offline   Reply With Quote
Old 05-09-2015, 08:45 AM   #18
WIDESIDE72
WIDESIDE72's Avatar
Imo one of the upgrades I would perform would be a factory tach in the instrument cluster. That way you could keep aN eye on the rpms. I did this in both my truck with oem parts.(aftermarket available as well,Although I have heard of issues with hei ignition and aftermarket tachs. I have hei and an oem tach in one truck with no issues.other. truck currently still has points.)
Alternately you could rig up an aftermarket tach on the column or under dash to get a idea of rpms.
Since its a new purchase, it might be a good idea to drain And refill all of your fluids, engine trans rear axle (don't forget power steering and brake fluid- I had a great uncle who was a schlumberger diesel mechanic, but that's a other subject). During rear axle service you will find two numbers stamped in the ring gear (43:14 or something to this effect) a little math (division) will give you your axle ratio.
Last edited by WIDESIDE72; 05-09-2015 at 08:50 AM. Reason: my kindle six and thinks it's smarter than me and tries to auto correct this vs like tach to taco
Old 05-09-2015, 08:52 AM   #19
WIDESIDE72
WIDESIDE72's Avatar
On a side note, funny thing..my wife's kindle sux and thinks it's smarter than me and tries to auto correct things like tach to taco. Just read the post above and replace tach with taco. Ooh, that reminds me, it time for breakfast. Guess what I'm having. Not pancakes.
Old 05-09-2015, 08:54 AM   #20
WIDESIDE72
WIDESIDE72's Avatar
Hmmm...tacos...
Old 05-09-2015, 09:07 AM   #21
Razorbacker
Razorbacker's Avatar
Very nice. That's a good looking Superhorn you have there.
Tony
1972 Chevy K10 SWB Custom Deluxe 350|350|NP205
2018 GMC Sierra Z/71 Crew
2008 GMC Yukon
2007 Chevy 1500 LT
1967 Pontiac Firebird 400
Razorbacker is offline   Reply With Quote
