Old 05-02-2015, 04:19 PM   #1
jim-bob
6-studs v/s 5-studs
...why do most folks change over their original 6 bolt hubs (axle) to 5? Like on my 67 GMC..
jim-bob is offline   Reply With Quote
Old 05-02-2015, 05:11 PM   #2
TBONE1964
Cluster King
TBONE1964's Avatar
Re: 6-studs v/s 5-studs
Number one answer will be: Because there are 78 percent more wheel options for 5 on 5 wheels than there are 6 lug wheels.
You can buy 5 lug axles for your rear end (with a spider gear kit) but the front is more of a challenge unless you are doing a disc brake conversion. Then it is as easy as finding a 71/72 C10 pick up and swamping the complete cross member as they are disc brake with 5 on 5.
Hope this helps,
Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
Old 05-02-2015, 05:14 PM   #3
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
More options for custom wheels and stock 71 and 72's had factory disc brakes (5 lug).
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 05-02-2015, 05:41 PM   #4
jim-bob
Hope this helps,
Tom
..I'm not sure i follow you, I'm sorta dense.. I do want disc brakes all way around but are you saying there's no conversion kit offered for the original 6 lug pattern...What do you mean "swamping the complete cross member"??
Old 05-02-2015, 05:59 PM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
There are many 6-lug disc brake kits.
CPP, McGaughy's, Early Classic Enterprises, Performance Online all have 6-lug kits.
The 67-72 trucks don't require a spider gear set to convert the rear axles to 5-lug.
And swapping used 71-72 or 73-87 crossmembers to get 5-lug rotors up front is a thing if the past!
All spindle manufacturers make direct bolt on spindles now.
No need to do a crossmember swap.
Keith
Convert to disc brakes.
Old 05-02-2015, 06:22 PM   #6
hugger6933
No need to swap unless your on budget restrains and/or have a bunch of truck parts laying around. Jim
hugger6933 is offline   Reply With Quote
Old 05-02-2015, 06:25 PM   #7
In The Ten Ring
I'd stick with the originals man.
In The Ten Ring is offline   Reply With Quote
Old 05-02-2015, 08:24 PM   #8
jim-bob
..you mean stay with the 6-lug?
Old 05-02-2015, 08:29 PM   #9
jim-bob
..thanks Keith..so staying with 6-lug will just limit my choices in buying wheels..Is there any other roadblocks?
Old 05-02-2015, 08:43 PM   #10
In The Ten Ring
You betcha! If you can get disc brakes that will work with the 6 lug, then why change? How custom to we have to be concerning rims anyway?
Old 05-02-2015, 08:54 PM   #11
lolife99
lolife99's Avatar
Just remember MOST 6-lug aftermarket wheels, made TODAY,... are for the 99-2015 silverado trucks.
Same bolt pattern,... but the center bore is way smaller than the 6-lug wheels built before 1971.
The hub on your 6-lug rearend is way bigger.
Personally I would switch to 5-lug.
It's a toss up on money.
Aftermarket 6-lug rotors vs aftermarket 5-lug axles.
Wheels selection will be greater in the 5-lug 5x5 pattern.
Keith
Old 05-02-2015, 10:59 PM   #12
TBONE1964
Cluster King
TBONE1964's Avatar
Not to argue Keith but it was my understanding that the 6 lug axles from 65-69 had a different spline count than the 70-72 axles which is why I thought you would need to change the spiders. I may be very well mis informed on that.
And yes there are certainly many options other than cross member swaps depending on a persons budget.
Good information,
Take care,
Tom
Old 05-03-2015, 04:34 AM   #13
lolife99
lolife99's Avatar
Only the 63-64 rearends require the spider gear swap along with new axles.
https://www.performanceonline.com/19...IDER-GEAR-SET/
http://67-72chevytrucks.com/vboard/s...d.php?t=603025
Keith
Old 05-03-2015, 08:13 AM   #14
jim-bob
..thanks to all..great info..believe I will change over..
