Old 04-21-2015, 03:52 PM   #1
1911a1
1911a1's Avatar
starter problem
My jegs mini starter broke the pinion gear retainer. The starter developed a noise sounding like it was hung up or clashing very loudly and buggered up the flywheel teeth some. the starter gear has 9 teeth. the flywheel is a 168 tooth. and the block has a staggered bolt pattern.
the flywheel may be salvageable. can I use a starter from a late '98 chevy 1500 with my set up? fro some internet search it appears so.
1911a1 is offline   Reply With Quote
Old 04-22-2015, 08:13 AM   #2
1911a1
1911a1's Avatar
Re: starter problem
Has anyone used the late model 96-98 starter on a 168 tooth flywheel and staggered bolt block?
Old 05-03-2015, 06:53 PM   #3
1911a1
1911a1's Avatar
Re: starter problem
Thought I would reply on the result of installing the '98 vortec starter on my GM goodwrench block incase anyone searches in the future for this issue.
It works like a charm. No shims.
Old 05-03-2015, 07:33 PM   #4
john
member #16
john's Avatar
Re: starter problem
Thanks, which brand did you use?
john is offline   Reply With Quote
Old 05-03-2015, 07:56 PM   #5
1911a1
1911a1's Avatar
Re: starter problem
AC Delco professional 337-1022. Its new for 113$ delivered. Its small w/ aluminum case fits around the headers great. looks good too.
Old 05-03-2015, 08:17 PM   #6
johnmiller66
Active Member
Re: starter problem
I ordered one from motor city reman. Part number on the box is 6562n. Works great. I'm thinking it was 78.00
johnmiller66 is offline   Reply With Quote
Old 05-04-2015, 05:47 PM   #7
Big Kev-O
Big Kev-O's Avatar
Re: starter problem
I am using a 96 c1500 starter from autozone, staggered bolt block & 168 tooth flywheel. I shimmed it using some of the "Help" shims that I bought when I purchased the starter. I used a number 2 paper clip to set the gap between the teeth. I had alot of issues until I figured out that the starter needed to be shimmed and the correct mounting bolts (GM part #12338064) need to be used. Engagement has been nice and smooth since.
Made in America by Americans
Big Kev-O is offline   Reply With Quote
