05-05-2015, 02:16 AM | #1 |
In the Forgotten far North.
At first i thought i'd lost a wheel..........
On my way to work on the 1st of May, I had to stop at a 4 way intersection in a not too particularly safe part of town less than 5 blocks from work.
As I lifted my foot off the whoa pedal and started to press on the go pedal, the rear end started to buck and shake..... then... the right rear dropped... with a very hard THUNK!!! I had been brought to a dead stop in the middle of the intersection. I got out to see what the frack happened and saw this.......
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
05-05-2015, 02:21 AM | #2 |
Re: At first i thought i'd lost a wheel..........
Needless to say what had happened is during the winter the rear end developed a leak and the right rear wheel bearing finally seized up on me and snapped the axle. So it now sits with the rear end on a jack stand looking like something old man Howard Stark was trying to create....
05-05-2015, 02:29 AM | #3 |
I hadn't noticed the leak because I go to work in the dark and come home in the dark and never noticed the oil puddles until way, way, way, too late.
And I never walked around the right rear of my ride before then either. It bent the hell outa my disc brake conversion caliper mount and snapped the caliper mount bolts clean off. the only thing keeping the wheel attached to the truck was the braided steel brake hose.
05-05-2015, 06:56 AM | #4 |
Wow, good thing no one was hurt. That's a good SS brake line!hahahah What's the plan, swap axle or the whole housing?
1973 k20 Suburban 350 1974 Custom stepside c-10 250 1975 Chevy stepside 454 1986 K30 Crewcab SRW 350 R.I.P- glimmertwin01- board member and good friend, you will be missed |
05-05-2015, 09:02 AM | #5 |
Woah! Good thing that broke at walking speed.
Greg 64 GMC Suburban - 283, NV3500, 14 bolt 77 C10 swb - 292, SM465, 12 bolt |
05-05-2015, 09:07 AM | #6 |
I saw a vid a couple of days ago where a burb on the interstate lost a rear wheel...it did a couple of 360's, tapped a car then hit the wall. You got lucky.
John 82 Chevy Silverado 350ci/TH350 |
05-05-2015, 10:04 AM | #7 |
It bent the lip of the tube at the top so yeah, I'm gonna have to replace the whole assembly.
05-05-2015, 10:09 AM | #8 |
Considering I was just on the highway not 5 minutes before this doing almost 70.... I'd have to say I had a co-pilot of biblical proportions with me that day.
05-05-2015, 10:29 AM | #9 |
need more info on disk brake swap
05-05-2015, 10:37 AM | #10 |
78K & 79C Jimmys
WOW you said it!
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
