How do you know if your governor is bad?
I'm having shifting issues on my TH 400. It won't come out of 1rst gear. The RPM will go up and never shift, especially when going up hill, and there's a pop that comes from the exhaust.
I pulled the governor out and it seems to be fine. The nylon grooves look intact. Is that the only symptom of a worn governor? I'm also replacing the vacuum modulator and changing the fluid and gasket while I'm at it. Anything else I should look at? |
#2 | |
Re: How do you know if your governor is bad?
If it is the modulator you should still be able to manually shift from L2 to L1 to D. |
![]() Join Date: Dec 2012
His last name is BROWN!!!!
Sorry I could not resist!! Cali guys will get it!!! check the modulator like Jonlopes said!
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO ![]() |
#4 | |
![]() Join Date: Jan 2007
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce Survivor "Lil’ Mint" (67 c10 40k mile light green original paint) Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
i thought you recalled that guy then he is running things again? The 400 ought to powershift as it used to be called that is when it holds first and then hop to second after the rpms get so high. or maybe I just dreamed that. Jim
That was another color Gray Davis was recalled. I just remember years ago where my vacuum line came off my modulator and it would not shift out of first gear
Paging Moonbeam....earth to Moonbeam....how's your bullet train to Coalinga coming along....Phase 1 projected costs - $68 BILLION making it the most expensive public works project in US history...
Let me apologize now for the outburst....just explaining why I'll be leaving CA |
#8 | |
Moderator
![]() Join Date: May 2007
Check the vacuum modulator, same thing happened with mine a while back. The vacuum line was cracked.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
XVIII. Posts regarding politics or religion are strongly discouraged. These posts tend to create pissing matches and will be closed.
Moderator
Please keep politics out of this, I do not want to close a thread in which the OP needs real help in fixing a problem with his truck. Thank you.
Sorry I was just cracking a joke. My apologizes to guy dudebro and the rest.
![]() Join Date: Feb 2009
Your tranny is all over the map. Had that happen on a 78 Caprice. Amco said I needed a new tranny. The local replaced the governor for 60 bucks. But that was about 1980.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
