#2126 |
Re: What did you do to your truck today? Chapter II
Going to have a tropical storm this weekend so I pulled my inner fenders yesterday so I can sand and pain this weekend in the garage (John Deere blitz black). Also plan to rebuild my gauge cluster while I'm stuck inside.
1970 Long bed- Stress release "There are only two kinds of people that understand Marines: Marines and those who have met them in battle. Everyone else has a second-hand opinion." Unknown ![]() |
#2127 |
![]() Join Date: May 2012
#2128 |
RE : shock absorbers ~
Bilstein HD's top any of the usual Hot Rod brands plus they last even when worked hard . If you go the KYB route , be aware the silver colored gas KYB's are crap , low quality shyte to sell cheaply , only the white KYB's are any good . Lotsa nice works here as usual ~ I always enjoy reading what you alls are up to ![]() I visited my truck in the Paint Jail , as usual , they screwed up something else and tried to blame me , I dropped off my 7th hub cap and he said ' O.K. now i finally have a full set of 5 right ? ' . Only if his employees are stealing them.... They managed to ' loose ' the original door mirror screws , last time I was there he said (as usual) ' no problem , I have them safely cleaned and ready for paining ' ~ when I went by Thursday I noticed crappo Chinese stainless steel allen headed screws and asked him ' oh , yours were no good and broke coming out ' . I see he has several 1950's & 1960's vintage GM trucks in there , I surely hope my hard won , unobtanium hardware isn't being re directed ~ I spent the last FIVE YEARS chasing down hardware , every bit of it original and un damaged , he wants to use all new and I don't . Wait'll you alls see the paint , it's wonderful .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH ![]() |
#2129 |
O.K. ;
I supposedly have a restored original AC box coming from Texas , I was in the Yakr this morning and spotted two AC equipped trucks and decided to get to work just in case :
#2130 |
This pic shows me where to use the chassis punch to change my non AC core support to an AC one , factory style :
Here's the first one removed : Attachment 1400872
#2131 |
More hose routing details :
AC pipes where they attach to the battery box : This was a '67 with really nice cab , NO RUST too bad they wanted $700 (GASP) for a BARE cab !
#2132 |
Here's the *perfect* if dusty heater box with the leak free heater core that dripped fresh coolant all over me and the wheel barrow :
Shake all the leaves out , pay $100 for all this plus a lot more and go home to begin cleaning , take it all apart : Wait ~ didn't I shake 2 # of leaves and black widow spiders out in the Junk Yard ?! ![]() My driveway's a mess and I have not yet begun cleaning all this delicate 40 year old plastic & fiberglass :
#2133 |
Oh crap ~ this is the only cleaning pic that came out ~ I used that " Fabuloso " cleaner stuff as I've had good luck with it :
Remember I said " delicate 40 year old plastic " ? : Gotta be really careful schlepping this stuff around the Yard : I didn't realize I'd broken this box in TWO PLACES until I was home taking it all apart for cleaning . So that's it for to - day , I set everything up to dry and will post pix of it later , the sun went away while I was finishing up . This AC stuff isn't rocket science , you just need to be REALLY CAREFUL or maybe be smarter than I am and buy a nice simple Vintage Air setup but I'm old and stuck in my ways , the only new things I want on this rig is a SANDEN AC compressor and an electric pusher fan on the condenser as that'll make the cab much cooler .
#2134 |
Started off by pulling starter and replacing a bad freeze plug, then adjusted my shirt lever, then replaced my leaking electric fuel pump , but the new one would not pump , tried it 3 times old then new... old pumped but leaked, new no pump.
As the truck stands now this is the only thing that I know of ,keeping it from being my daily driver. |
#2135 |
I fought with my in-cab fuel line for a couple of hours. What a test of patience! I got it shortened and re-bent around enough to work but I'm not happy with it. I am going to try and bend a piece of copper wire around to my liking and then use that as a model for the tubing.
#2136 |
Got up too late to work on the truck (garage too hot in the afternoons) and I needed to patch a screen door anyway so I just cleaned up the gas tank and seat bolts.
I had one break off and it seems I've lost one so I found what I needed in dad's stockpile. The "Evaporust" is pretty neat stuff although I prefer "Krud Kutter" (phosphoric acid). ![]() Last edited by In The Ten Ring; 05-10-2015 at 08:49 PM. |
#2137 |
#2138 |
![]() Join Date: Nov 2014
Started taking mine apart to tackle the rust in the cab.
67 Chevy Shortbed Fleetside C10 400 SBC/Turbo 350/Posi 62 Impala SS (Clone) 350 SBC/4 Speed/3:36 Posi Rear 2003 Silverado Crew Cab (Black) 2500 HD 4x4/6.0L/Auto/Posi Last edited by Ol 67 C10; 05-10-2015 at 09:01 PM. |
#2139 |
#2140 |
More pics...
67 Chevy Shortbed Fleetside C10 400 SBC/Turbo 350/Posi 62 Impala SS (Clone) 350 SBC/4 Speed/3:36 Posi Rear 2003 Silverado Crew Cab (Black) 2500 HD 4x4/6.0L/Auto/Posi |
#2141 |
What part of West Virginia are you located? Im only about 20 minutes from Mathias,WV. Its in Hardy County.
#2142 |
Friday I drained and filled the New Process 435, yesterday and today I greased the front end. I had a missing Zerk on the outer driver's tie rod link, so had to fit a new one. Lots to oil and grease on these old trucks. A must if yours is manual everything...
Dennis Nichols 1969 GMC C2500 305E V-6 The Mule 1986 Toyota 4Runner 1959 MG MGA Coupe |
#2143 |
cut off 26 factory rivets to dump the rear shock mounts, bent rear frame support, front tranny mount & trailing arm x member. that sucked! but.....safety first!!!
#2144 |
I finally got my seat and carpet redone. One more thing checked on from the list.
Go BIG or GO home!! 1970 Custom Chevy C10 / 350 bored .30 over / 5.5/7 drop on 20" boss 338 ![]() |
#2145 |
![]() Join Date: Feb 2011
Nice!
#2146 | |
RAT1968 '68 Cab/'71 Parts
Too nice not to flip.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
#2147 |
Nice spidermn! I'm only about 35 minutes from Waynesboro.
#2148 |
Nice to see someone from my neck of the woods. Never seen anyone else on here near me.
Thanks for flipping them for me. I didn't preview them before posting. Plus they look much better the correct way.
#2149 |
I am in southern WV.....once I get my truck running, how about all members within 100 miles of us get together for lunch or some beers?
Today I bent a piece of 12-2 wire (just one wire, not all 3) into the shape of how I thought the in-cab fuel line should go. I then bent 3/8 inch tubing to match that. OMGosh it is nearly perfect! I think it would work BUT I have a kinked bend so I am going to try again tomorrow. I also got the seat bolts coated with rust converter after cleaning in Evaporust for a couple of days. ![]() ![]() I did come very close though......but for the kinked bend. ![]() Last edited by In The Ten Ring; 05-11-2015 at 08:44 PM. |
#2150 |
