#1401 |
![]() Join Date: Mar 2013
Re: Donz '65 SWB Stepper Budget Build...
Acorns help with lubrication.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
#1402 |
Show looks like it went over good.
No pun intended....but that's nuts. It always amazes me the places critters can get into.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
#1403 | ||
![]() Quote:
![]() Obviously, the rags and tape, as well as the plastic bag that encased the motor on the stand, were no match to the craftiness of the guilty creature... ![]() The thermostat housing, sans thermostat, was the entry point... ![]() Note to Self… Next time you have a motor on a stand, set the thermostat in place to allow for quicker and easier removal of food stash... ![]()
DON Proverbs 27:17 ![]() US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD |
#1404 |
Well at least you found a good place to keep food hidden..ya know...those sweet we're not aloud to get sometimes.
#1405 | |
#1406 |
Tuesday, when I had planned on the start-up, I realized all the fuel line I had on hand was 5/16ths and the Fuel Filter and Pump have 3/8ths fittings...
![]() So, yesterday, along with the Lower Rad Hose, I grabbed a handful of 3/8ths Fuel Line… Upon arriving home I put the Lower hose on and the Brother-in-law returned with my daily driver and a weird noise under the hood... ![]() Popped the hood, listened to a noise that seemed to be steady yet sporadic… Didn't sound internal, so we switched it off and upon looking found this… ![]() ![]() P/S Pulley gave up the ghost... ![]() I traded a '71 Super Beetle (That I had a total of $50 in) for this truck and about 6 months after getting the truck I had to put intake gaskets on it. At that time I noticed the P/S Pulley had a mark across the grooves. The mark was similar to a mark made by a chisel... ![]() ![]() Luckily, I had on hand an extra pulley, so about 40 minutes later the DD was back in business... ![]() Start-Up coming soon... ![]()
DON Proverbs 27:17 ![]() US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD Last edited by Ta2Don; 05-14-2015 at 09:45 AM. Reason: move sentence |
#1407 |
Looking forward to it brotha!
#1408 |
In the infamous words of Igor… "It's Alive!!!"
![]() ![]() ![]() https://youtu.be/NfhAIelI9aY This is my first attempt to load a video and embed it here… Oil Pressure holding just over 50psi at idle… First attempt at cranking resulted in nothing but the starter spinning the motor over… We pulled the distributor and rotated back one tooth, re-installed and she fired right up... ![]() Feeling good, now to re-install cab and get after re-assembly... ![]()
DON Proverbs 27:17 ![]() US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD Last edited by Ta2Don; 05-18-2015 at 06:05 PM. Reason: video link |
#1409 |
Well done Don I bet you are pleased . Getting the motor running is such a great way to get motivated into getting it finished
FINALLY PUTTING IT BACK TOGETHER AT LONG LAST MY BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=611614 |
#1410 |
Rollin' Old Skool
Congrats on firing the engine!
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
#1411 |
Congrats!
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
#1412 |
Awesome brotha! I'm yer 1st sub on youtube!
#1413 |
#1414 |
Thanx Brotha!!!
#1415 |
Very cool!
Way to Goooooooooooooo.
Vince Galatians 6:14 62 SWB stepside, 94 Wrangler, 99 Z71, 99 vette My Project http://67-72chevytrucks.com/vboard/s...d.php?t=719086 "If it's too loud, you're too old" ![]() |
#1416 |
Thanx Guyz for looking in and the kind words...
![]() Today I fired it up again in order to bleed the P/S system and check the operation of the P/S Box… https://youtu.be/UQWFmwRlkTo Then I fired p to get a few revs in... ![]() ![]() http://youtu.be/CwMQbzS3xuc The Engine is holding 52psi Oil Pressure at idle after warmed up… ![]() ![]() I also found that a pack of hose clamps I purchased at a truckload tool sale are garbage… Tightened this one up on the hose and after the short time running I found this… Tried to check the tension on the clamp and it is stripped and not holding tension… ![]() ![]()
DON Proverbs 27:17 ![]() US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD Last edited by Ta2Don; 05-19-2015 at 09:37 PM. Reason: add comment |
#1417 |
I tried again TJ, and all I get is the link in blue...
#1418 |
Try this brotha.
#1419 |
#1420 |
No updates relating to the build… but it's been a crazy weekend…
Firstly I want to Salute my fellow Veterans this Memorial Day... ![]() I was honored Saturday to be able to perform not only my son's wedding, but also the wedding of some friends/clients of mine… The son and his lovely bride were married at Vino's Pizza & Brewery in Little Rock at 12:30pm and at 6pm I married Joseph and Hannah at their home in Rosebud… Just a few pics and aiming at some truck time tomorrow... ![]() The Nuptials… ![]() The Bride & Groom…Jeremy & Sarah ![]() The Wedding Party… ![]() Proud Momma and the Happy Couple and this old guy!!! ![]() ![]() Finally, Hannah & Red… ![]() ![]() ![]()
#1421 |
Happy Memorial Day to ya brotha!
![]() Thank you for your service. ![]()
#1422 |
Congrats to you and your gang Don.
Looks like it was a great day for all. Maybe we should rename you "Packin' Preacher" Unfortunately in the UK Vets and service men/women are not respected in the same way. In my former country the same applies. So to my adopted brothers - Thank you for your Service.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
#1423 |
Congrats to all
#1424 |
![]() Join Date: Oct 2009
really nice looking group. love the pic with bridesmaids and groomsmen. congrats to you buddy and it looks like some of your best work.
happy day... |
#1425 | ||
Thanks TJ
![]() Thank You! Quote:
Tags |
65 swb, c10, step side, tattoo |
