Old 05-13-2015, 05:49 PM   #1
Jaymans82
Jaymans82's Avatar
Rear End Gears
Hello
I have a 82 chevy c10 LWB with a 383 stroker with a 700R4 with lockup.
I think my gears are 308's which I think are to high. What gear should I go with 342 or 373?
Jaymans82 is offline   Reply With Quote
Old 05-13-2015, 07:50 PM   #2
Jake Wade
Jake Wade's Avatar
Re: Rear End Gears
I personally like a 3.73 with a 28"-30" tire and a 700R4.
3.42 for 25"-27"
Jake Wade is offline   Reply With Quote
Old 05-14-2015, 07:19 AM   #3
Keith Seymore
Keith Seymore's Avatar
Re: Rear End Gears
3.73.
They are perfect with the overdrive trans.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 05-14-2015, 08:17 AM   #4
77c10
77c10's Avatar
Re: Rear End Gears
What Keith said....
77 C10, 6.0LS/4L80E, 3:73 12 bolt. Boss 338's 20" x 10" w/ 285/50/20 rear. 20" x 8.5" w/ 245/40/20 front. Vintage Air. Full Autometer gauges recessed in factory bezel (Thanks bigblock73!) Gm Storm Grey Metallic paint
"Cool ain't ever cheap and cheap ain't ever cool"
77c10 is offline   Reply With Quote
Old 05-14-2015, 10:41 AM   #5
piecesparts
Parts and more parts
piecesparts's Avatar
Re: Rear End Gears
Originally Posted by 77c10 View Post
What Keith said....
Yep, we are all in agreement, the 3.73 works the best with a 700 R4 tranny.
My truck is a 383 stroker, 700R4 tranny, 28" tall tire, with a 12 bolt 3.73 geared rear end.
Frank
Old 05-14-2015, 11:28 AM   #6
Jaymans82
Jaymans82's Avatar
Re: Rear End Gears
OK I'm guessing when you say 12 bolt that that is the bolts on the cover. If so I only have 10 bolt. should I find a 12 bolt are is a 10 good enough?
Old 05-14-2015, 09:32 PM   #7
RIDE-RED 350r
RIDE-RED 350r's Avatar
Re: Rear End Gears
I don't know about your area, but here in my area I had a heck of a time sourcing a 12-bolt truck axle when mine grenaded last summer.
I don't know whether or not a 12-bolt is that much heavier duty than the 10 to justify the search for one. The ring gear in the 12-bolt is little larger than the 10-bolt (8.875" to 8.5" respectively) Also, the 12-bolt uses 12 bolts to fasten the ring gear to the carrier where the 10-bolt uses 10.
I am not certain if there are more things the 12-bolt axle has over the 10 beyond that, or if these make the 12-bolt significantly tougher either. I would defer to some of the more experienced members here on that subject.
Also, it should be noted that the 12-bolt passenger car axle is different than the truck axle. The car axle seems to be more desirable to builders from what I gather. Seems like I have read that the truck axle has a smaller pinion shaft.
But if it were me and I intended to flog an axle with bigger HP and torque and decided to swap axles for something better suited to that than the 10-bolt, I would get something heavier than the 12-bolt..along the lines of a Dana 60 or GM 14-bolt FF.
Who needs a Hemi when ya got a Chevy!
RIDE-RED 350r is offline   Reply With Quote
