Old 05-14-2015, 08:19 AM   #1
Paul Y
Adding X bracing to the chassis. Who's done it?
Gentlemen,
Done a bit of research on the matter, looked at the post by Mr Astronaut (http://67-72chevytrucks.com/vboard/s...d.php?t=495785) and the how to make it handle thread by Rob.
I cant quite visualise what Rob is discussing and Mr A's is probably more detailed than I want to attempt.
My question is, therefore, who else has added X Bracing to their truck and how did you do it? Pictures would be really useful!
As for why... Well have got part of the way through my suspension upgrades ( front ARB relocated shocks, dropped spindles etc) and am going to be removing the bed over the long weekend to affix the rear ARB along with cleaning and painting the rear chassis.
It seems like the obvious time to add the bracing plus, as I intend to use Woody in autocross events, it is a cheap upgrade.
Over too you.
P.
Paul Y is offline   Reply With Quote
Old 05-14-2015, 03:25 PM   #2
LVPhotos
LVPhotos's Avatar
Re: Adding X bracing to the chassis. Who's done it?
http://pbfab.com/shop/inner-frame-stiffener-61
As seen on Gas Monkeys truck
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 05-14-2015, 04:20 PM   #3
Paul Y
Very nice but about $1,998 more than I have to spend....
I was thinking along the lines of something like this using thin wall tubing...
Am I on the right track?
Do I need the rear most 'X'?
The forward 'X' I plan to tie into the gearbox cross member in some way.
Is it worth boxing the frame? I think i will get more out of the X bracing but keen to hear what others have done.
P.
Old 05-14-2015, 04:36 PM   #4
Paul Y
Using a little GoogleFoo found this which is sort of what I have in mind...
P.
Old 05-16-2015, 04:34 AM   #5
Paul Y
A little weekend bump for those that might like to share their knowledge....
P.
Old 05-16-2015, 11:50 AM   #6
Vincenthdfan
Hmmm...making it look remarkably similar to my stock '62 frame!
Lol...sorry, couldn't resist.
Vincenthdfan is offline   Reply With Quote
Old 05-16-2015, 03:26 PM   #7
tinydb84
tinydb84's Avatar
Paul is that WastedIncome's blazer?
David
Instagram: myfabguy
Old 05-17-2015, 03:39 AM   #8
Paul Y
Not 100% sure as I found the picture on Google images.
Will have a search later and see what wasted income did to his truck.
P.
