Old 05-17-2015, 07:05 PM   #1
ProStreet83C10
Drag Racer
ProStreet83C10's Avatar
Cragar S/S wheel lug nuts???
Hey guys, i picked up some used Cragar S/S wheels - without lugnuts, and id like to know which of these lug nuts my 83 C10 takes.
Not sure what all this means haha
.800 SHANK MAG STYLE LUG NUTS & WASHERS - 5x4.5, 4.75, 5 BOLT CIRCLE
27721-4 7/16 RH with center hole washers .684 Diameter
27723-4 1/2 RH with offset washers .684 Diameter
27727-4 1/2 LH with offset washers .684 Diameter
27780-4 1/2 RH with center hole washers .684 Diameter
27792-4 7/16 RH with offset hole washers .684 Diameter
27846-4 14mm-1.50 with center hole washers .750 Diameter
27732-4 12mm-1.25 RH with center & offset hole washers .684 Diameter
27733-4 12mm-1.50 RH with center & offset hole washers .684 Diameter
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
ProStreet83C10 is offline   Reply With Quote
Old 05-17-2015, 07:09 PM   #2
J Knight
J Knight's Avatar
Re: Cragar S/S wheel lug nuts???
Ok....27723-4
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 05-17-2015, 10:01 PM   #3
Titomars
Titomars's Avatar
You need to determine whether your rims are uni-lug or single pattern. Uni-lugs have the egg shaped holes and seats for multiple bolt patterns. Single pattern are for a single bolt pattern like 5 on 5 for our C/10's. Most S/S's came uni-lug but I have seen some in single patterns too. if its single you want centered washers. If it's uni-lug you want the offset washers. The threads are 1/2 RH for our squares with 5 lugs
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt.
1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt.
Titomars is offline   Reply With Quote
Old 05-17-2015, 10:14 PM   #4
ProStreet83C10
Drag Racer
yeah their uni-lug, sorry
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
