05-17-2015, 10:40 PM | #1 |
The 60-66 GMC/Pontiac guy....
Build 4 of 4... The BIG Dually. ..
Here we go.. yup... the build that ends my builds..
I came across a 67-72 C30 C&C chassis.. I've been toying with the idea of building a contemporary powered 60-66 dually for a long time... :-) The price of free with free delivery was too good to pass up. The Plan..... Taking 30" out of the 157" wheel base and 6" off the tail. That should result in a 127" wheel base and a frame the correct length to take a stock long bed box on it. I want it much lower than stock, static suspension, able to pull a serious trailer. .. 5th wheel, goose neck or ball and receiver.. Here is the frame. .
Building Genuine Pontiac Firepowered cars and trucks for several decades. Why Pontiac?? That's just me daring to be different. Projects.. 63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction. 440CID 2X4 Pontiac |
05-17-2015, 10:43 PM | #2 |
Re: Build 4 of 4... The BIG Dually. ..
I'm using a 97 dually as a donor truck.
5.7 Vortec. .. 4L85E. .. All the electronics, A/C... everything
05-17-2015, 10:51 PM | #3 |
In for the build. This will be sweet.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
05-17-2015, 11:09 PM | #4 |
Going with a 63 GMC cab... fleet long bed with stepside fenders recessed into the fleet bed...
And this is the front clip theme that I'm going to copy..
05-18-2015, 08:50 PM | #5 |
I'm using a 67-72 steel bed floor on this build.
It's fitted to the frame now. The rear frame rails on the C30 frame sit about 3" higher than a stock 1/2 ton frame. This means the bed floor will be raised inside the bed 3 inches. I had to take 6" off the rear.. I am using a frame section out of a 3/4 ton to support the front 1/3 of the bed. Raising the floor was a concern at first but after measuring I can now see the 5th wheel hitch will sit below the top of the bed sides.. That's good because I want to use a fiberglass tonneau cover.
05-26-2015, 10:06 PM | #6 |
Bought a 62 cab and brought it home to use as a donor for an extended/crew cab.
I just couldn't bring myself to cut the frame and extending the cab just seems like the right thing to do... I'll be posting some photos tomorrow.
05-26-2015, 11:32 PM | #7 |
Can't wait to see pics. I'm thinking something on the same lines
05-27-2015, 08:51 AM | #8 |
Will be one great looking front end. I like where your going on this build!!!
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
05-27-2015, 09:29 AM | #9 |
Yeah. ..
My day off today will be filled with moving forward on the trucks.. Take some photos. ... Move forward a bit more... Take more pictures. .. However. .. I'm really on the fence about doing a 30" extended cab or shorten the frame 30 inches. I should be able to make up my mind by the end of the day. I hope..
05-27-2015, 04:55 PM | #10 |
1961 crewcab
here is some real good info on the correct way to do a notch for strength, I was originally just going to do a "deep" pipe notch, but after looking at this I think I will use the c notch kit I have...
http://talk.classicparts.com/showthr...964#post96964/ I got about 8 inches on my 66 1 ton frame just by doing the "flip kit" on the axle.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
05-27-2015, 07:47 PM | #11 |
I'm not notching the frame...
But the information was very good.
05-28-2015, 10:56 AM | #12 | |
I haven't finished preparing the bedfloor fitting for exact measurements but I'll need to raise the bed floor approximately 4 inches.. because of the frame. . I am going to lower the truck but not in the ultra extreme way some on the forum have... It's a nice look but my dually will need to be fully functional to pull a heavy trailer. :-D A notch will not be necessary at all.. I will however, be scouring the local wrecking yards to find a leaf hanger. .. some brainiac torched a chunk out of one
05-28-2015, 01:03 PM | #13 |
I'm in to watch this baby mature.
07-19-2015, 07:56 PM | #14 |
As things have progressed on this project. .. as parts were being collected. .. I got a huge pile of stuff collected on the bed floor of the truck.
Frankly, I've been all over the board on this build. Drop it.. don't drop it... dually 1 ton... single wheel half. .. A crew cab is about the only thing I'm concrete on doing.. Now there is a 4X4 idea that won't go away. . I'm glad there are 2 other projects in front of this one.
03-09-2016, 10:32 AM | #15 |
It's been a while since I have updated..
I need to get some photos together and update
10-19-2016, 10:00 AM | #16 |
I've been collecting parts for months and have done absolutely no work on this project, whatsoever.
I do have enough parts now to build it. But no time. It's buried under a ton of other project parts... I'll see if I can, at the very least, get photos.
