Old 05-18-2015, 12:20 PM   #1
raic65
raic65's Avatar
My 67 Cougar Build
Sorry everyone that it's not a chevy, Here is another build I have going. I started this build a couple years ago. It is a slow build. And I mean really slow.
I started with this:
raic65 is offline   Reply With Quote
Old 05-18-2015, 12:21 PM   #2
raic65
raic65's Avatar
Re: My 67 Cougar Build
Here are a few pics of the front brakes I will be installing.
Old 05-18-2015, 12:21 PM   #3
raic65
raic65's Avatar
I did some prelimnary mock up with the coyote engine.
Along the way I built an engine lift fixture because I didn't feel comfortable with the lift brackets supplied with the coyote engine. I can see them bend as I lifted the engine. Getting the CG right also proved to be cumbersome with the supplied lift brackets.
Old 05-18-2015, 12:22 PM   #4
raic65
raic65's Avatar
To date, I have mostly installed the front suspension. Still need to weld upper control arm mount gussets, top coil over mount, and and the down tubes. I'll tie the gussets, coil over mounts, and down tubes together.
Old 05-18-2015, 02:43 PM   #5
NONHOG
NONHOG's Avatar
Dang! looks fun-subscribed.
"I feel the need for speed!"... as soon as I am done with my nap.
NONHOG is offline   Reply With Quote
Old 05-20-2015, 01:21 PM   #6
Low Elco
NIce! What CAD program?
Low Elco is offline   Reply With Quote
Old 05-21-2015, 01:26 PM   #7
raic65
raic65's Avatar
I'm using SolidWorks. I was fortunate to find the cad file for the motor online and discover the locations of bolt holes and such was accurate.
Old 07-06-2015, 06:07 PM   #8
raic65
raic65's Avatar
Small update. Fabbed and tacked motor mounts in. Hope to finalize engine placement this weekend, then I'll install the engine and transmission so I can fab a transmission cross member.
Old 07-20-2015, 10:34 AM   #9
raic65
raic65's Avatar
Another update. Mocked up the hydroboost to see if it will clear the coyote motor. I'm borrowing a reproduction boss 429 brake booster wedge to angle the hydroboost up. The results look promising. I will not need to offset the booster like I've seen in other builds.
Old 07-20-2015, 11:08 AM   #10
67ChevyRedneck
67ChevyRedneck's Avatar
Awesome!
This is what "alternate tinkerings" is for. There's another cool cougar build on here as well as few Mustang builds (including mine.)
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 09-29-2015, 11:23 AM   #11
raic65
raic65's Avatar
More updates.
Brake pedal mod for adapting an 03 cobra hydroboost to the cougar pedal support. I replicated the pedal ratio from the cobra.
Pedal support setup with hydroboost, S197 mustang hydraulic master, and roller bearing converison
Used parts from the S197 mustang and adapted them to the cougar clutch pedal.
Hydroboost mounted using a reproduction Boss '9 mustang brake booster wedge to clear the coyote engine.
Old 09-29-2015, 12:45 PM   #12
flashed
I have always loved the old Cougars and yours looks like a killer project so Im in to see the rest .
flashed is offline   Reply With Quote
Old 02-07-2016, 01:57 PM   #13
raic65
raic65's Avatar
A few updates. Was able to roll the car out of the garage this weekend on it's own suspension. Finished welding in the upper control arm gussets, upper shock mounts, and frame boxing plates. Still need to weld in the down tubes and shock tower delete plates, but I will first fab up the transmission cross member so I can return the coyote motor to my buddy.
Hope the car is not sitting too low once the real wheels and tires are on.
Old 02-07-2016, 02:51 PM   #14
flashed
Looking great ,that motor looks good too.
Old 02-09-2016, 12:30 AM   #15
Zoomin
Man of Mini-Talents
Zoomin's Avatar
What a sweet ride that's going to be! Love the early Cougars.
Zoomin is offline   Reply With Quote
Old 02-09-2016, 04:27 PM   #16
AldoWelds
AldoWelds's Avatar
Very slick man lot of work and detail going into this I am sure it will be beautiful when you are done!!
AldoWelds is offline   Reply With Quote
Old 02-22-2016, 10:44 AM   #17
raic65
raic65's Avatar
Thanks guys for the kind words. Small update from the weekend. Fabbed and installed my transmission cross member
Old 04-01-2016, 09:09 AM   #18
raic65
raic65's Avatar
Christmas came early.
Old 04-01-2016, 08:33 PM   #19
swamp rat
swamp rat's Avatar
Lots of nice work!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 05-31-2016, 09:47 AM   #20
raic65
raic65's Avatar
Just a small update from the weekend. Decided to cut the firewall out to make clearance for the Charge Motion Control Valves (CMCV) on the back of the intake. I didn't want to move the engine forward for the clearance because it would have created an issue with the steering linkage and oil pan. I figured modifying the firewall would be easier. I just wanted the firewall to remain looking "stockish" after the mod. I think I accomplished it. Still need to complete the metal finishing though.
Old 08-24-2016, 10:47 AM   #21
Flatty
Are there any updates on this build? I had a 68 cougar as my first car, and plan to do a build very similar to yours arfter I finish the 51 pickup for my wife.
Can you tell me what those a-arms are off of, and explain the front suspension in general? Was that a kit, or a custom build by yourself? If that was acustom one off piece, are you intersted in putting together another one?
Dima
1969 FJ40 Rockcrawler
1949 Chevy Pickup
2006 Powerstroke to tow
Flatty is offline   Reply With Quote
Old 09-12-2016, 09:28 AM   #22
raic65
raic65's Avatar
Dima
Very few updates. Fabricated the mount for the coyote control pack power distribution block and closeout panels for the shock towers delete. Also picked up a steering wheel along the way.
The front suspension is an Art Morrison Sport IFS that I integrated into the chassis. It is somewhat of a universal kit. I just ordered a kit based on the width of my framerails.
Old 09-12-2016, 09:33 AM   #23
raic65
raic65's Avatar
There are a few other updates I forgot to mention.
Dressed the welds on the firewall and reinstalled the coyote engine to check for clearances.
Old 10-27-2016, 02:24 PM   #24
raic65
raic65's Avatar
New valve covers for the coyote conversion. Excited what it will look like in person.
Old 10-27-2016, 02:25 PM   #25
raic65
raic65's Avatar
Machinist sent me this today. Machining on custom covers is almost complete.
