Old 05-18-2015, 04:55 PM   #1
vabeacheric
vabeacheric's Avatar
'63 3sp Saginaw to TH350 Swap
I'm sure this topic has been beaten to death but I've been unable to find a parts list or "directions" for making this swap. Obviously a trans, shifter, linkage etc... is necessary but can anyone tell me what else may be required to perform this swap? I'm primarily concerned with materials required under the truck. Thanks everyone in advance.
vabeacheric is offline   Reply With Quote
Old 05-18-2015, 05:09 PM   #2
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: '63 3sp Saginaw to TH350 Swap
Radiator with trans cooler. Or a separate cooler.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 05-18-2015, 05:28 PM   #3
LostMy65
LostMy65's Avatar
I did find these similar threads :
http://67-72chevytrucks.com/vboard/s...d.php?t=587314
http://67-72chevytrucks.com/vboard/s...d.php?t=265254
Old 05-18-2015, 05:56 PM   #4
The Rocknrod
Moderator
The Rocknrod's Avatar
The cross-member under your current 3 speed (at about the firewall) will go away. The cross-member for the tail-shaft of the TH350 will have to be installed.
The cross-member currently in place where the emergency/parking brake mechanisms are will most probably have to be removed.
This may help but remember it's a 62 not a 63:
http://67-72chevytrucks.com/vboard/s...d.php?t=626071
and
http://67-72chevytrucks.com/vboard/s...light=sbc+1960
Old 05-18-2015, 06:04 PM   #5
LostMy65
LostMy65's Avatar
As mentioned in the thread I linked; you'll need a starter that can mount to your block.
Old 05-19-2015, 07:12 AM   #6
vabeacheric
Thanks for the responses, guys!!! I suppose my concern in a cross member that is required to support the TH350. Does anyone make one for the '63 or is it something that I have to fabricate? I know that there are those on the board that fabricate plates for power steering boxes and brake master cylinders...
Old 05-19-2015, 08:41 AM   #7
The Rocknrod
Moderator
Classic Performance Products Inc (CPP)
Ebay
Old 05-22-2015, 07:57 AM   #8
vabeacheric
Smile Re: '63 3sp Saginaw to TH350 Swap
Thanks Master Chief!!! I've ordered that crossmember!! So far, I've got the crossmember, starter, trans cooler, and floor shifter....can anyone think of anything else???
Thanks in advance everyone!
