05-20-2015, 07:22 PM | #26 |
Re: olds 455 vs buick and pontiac 455s?
I would do a Olds or Pontiac. They have more torque under the curve, and stop. Due to there very long strokes.
Depending on gear ratio it won't effect mpg to much with tires since they do not seem to notice. If you are turning some rpm over 2750 the the short stroke Buick has an advantage with mpg. All are good engines, but I would look at my truck to decide on my engine. |
05-21-2015, 12:32 AM | #27 |
One of those monsters would make a great GMPP crate engine. Unfortunately, the only old school engines they make are Chevys. I'd also like to see a small block 400.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
05-21-2015, 01:22 AM | #28 |
Olds 455 is a bolt in, and with minimal effort will make 400+HP and approx 600 ft/lbs of torque... i have one in mine...
my personal favorite would probably be the Pontiac 400 block stroked to 461, the 400 block has smaller diameter mains, so more meat in the block.. also there are aftermarket blocks, and there are better heads available for the Pontiac...
My build thread... http://67-72chevytrucks.com/vboard/s...d.php?t=515829 Disabled Veteran 82nd Airborne Division Operations: Desert Shield, Desert Storm, and Uphold Democracy |
05-21-2015, 01:36 AM | #29 | |
the pilot bearing on the Olds motors may/may not be drilled.... also some Olds 455 motors don't have the clutch pivot ball thread hole drilled in the block, so you'd have to do hydraulic clutch... for the Pontiac look no further than Jim Lehart at http://centralvirginiamachine.com he's building me a stroked 400/461 now, roller cam, eagle rotating assembly, forged pistons etc. that will rev fine with stock 6x-8 heads, and factory intake manifold to 5800rpm, also in the 400+hp, 500+ft/lbs range price was right around 5000.00 complete was 4000.00 for just the short block for my Olds 455, they're pricey! LOL my Olds builder is in Winter Haven, FL. he's an EFI tech with Accel, Olds specialist... if you want an Olds motor built, or need parts let me know these other GM big inch motors are more interesting and a lot of fun to make big power with for me... total different animal than a Chevy SB/BB/LS or whatever, they are a dime a dozen, cheaper etc. etc. nothing bad about that, it is what it is...
My build thread... http://67-72chevytrucks.com/vboard/s...d.php?t=515829 Disabled Veteran 82nd Airborne Division Operations: Desert Shield, Desert Storm, and Uphold Democracy Last edited by naphtali5725; 05-21-2015 at 01:52 AM. Reason: added info |
05-22-2015, 09:52 PM | #30 |
So did you ever mention what you actually want to spend, odd engines cost a lot more, no surprise everyone runs a small block when trying to save a few $.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
