05-21-2015, 05:06 PM | #1 |
69 c10 door panel removal?
I am trying to get my door panel off to change the weather stripping & rubbers etc.
The related posts seem to skip the actual panel removal. Mine has the chrome strip at the top that seems to be screwed into the door. I removed the 4 screws at the bottom, and have tried to roll the panel up to release it. It is binding up about 4" tipped. I have tried pulling it down and out, doesn't seem to want to come. Is there a trick or step I have missed, don't want to ruin the chrome strip if I don't have to. Thanks |
05-21-2015, 05:10 PM | #2 |
Re: 69 c10 door panel removal?
it should just pull right out after you take out the four screws. no need to remove the chrome trim
1967custom |
05-21-2015, 05:24 PM | #3 |
Pry bar or hammer/screwdriver?
Oh wait. This isn't the Ford truck forum.
72 K2500 Sierra Longbed Wideside 350/TH350/NP205 66 Plymouth Barracuda 225 Slant6 |
05-21-2015, 05:43 PM | #4 |
Remove the arm rest, window crank, and interior door handle first.
Tony Nicholas @ Midwest Metal Masters 1953 Chevy 3100 392 Hemi w/727 & 9” Ford 1985 Chevy C/10 6.0L 4L80 373 locker |
05-21-2015, 06:02 PM | #5 |
once you take off the arm rest window crank door handle and the four screws you pull out at the bottom and then down. don't be timid with it, mine took a bit of force but it comes out.
05-21-2015, 06:50 PM | #6 |
No arm rest on this one unfortunately, door crank & window crank removed.
Does it pull straight down, or out and roll upwards? |
05-21-2015, 06:58 PM | #7 |
out and pull down. it might be stuck from 40 plus years of coke and gooey stuff being dropped on the door
1967custom |
05-21-2015, 06:59 PM | #8 |
It should pull out a bit to clear the window and door cranks, then slide straight down. As far as mechanics go, if it got any more simple it would be square peg in the square hole, no offense implied
05-21-2015, 07:13 PM | #9 |
I thought that's what looked like should be happening, I will just apply more determination. Thanks
05-21-2015, 08:16 PM | #10 |
it should pull out about and inch or 2 and then straight down. i had to really pull on mine o get them off just because the had been on for 40 years
