Old 05-22-2015, 11:29 AM   #1
Skunksmash
Skunksmash's Avatar
Belt too tight?
I recently had to replace my main belt on my 87 5.7L TBi. The only one that isn't a v-belt. It has the little ridges all across the underside and its about an inch wide. That belt. It was squealing horribly and was about to bite the dust.
So I replaced the belt, and the squealing stopped. But how do I know how tight to tension the belt? As I'm sure most of you know, you just use the alternator to tighten the belt. You just get your prybar in that hole in the alternator bracket, and pry on the side of the alternator while a buddy tightens the alternator bolt. Then presto, the belt has tension. But how much is too much? How far do you go? How can you even tell you're anywhere near the correct tension?
Same question for the V-belt that connects to the smog pump down below. You can change and adjust the tension on that belt just as you would with the main belt.
Skunksmash is offline   Reply With Quote
Old 05-22-2015, 12:28 PM   #2
jetmech85
Re: Belt too tight?
Search Amazon for "Gates belt tension tester" and see if that will solve your problem. I bought two sizes to cover the different size belts but haven't had the need to try them out yet. I think they are in the $10-$15 price range.
jetmech85 is offline   Reply With Quote
Old 05-22-2015, 02:28 PM   #3
Bigstevex4
Bigstevex4's Avatar
Re: Belt too tight?
You would have to get pretty aggressive to over tighten a serpentine belt as long as you push on it and get a little movement . V belt should be able roll them a 1/4 turn.
83 c10 long Box Daily Driver
90 Jimmy parked
98 Road King/ 06 Road Glide
In memorium
63 impala SS/ 65 Chevy Panel
65 GMC Short Box/ 68 Camero
Bigstevex4 is offline   Reply With Quote
Old 05-22-2015, 03:21 PM   #4
Skunksmash
Skunksmash's Avatar
Re: Belt too tight?
Thanks!!
