05-22-2015, 09:29 PM | #1 |
New Member Texas
Been looking on the website for a few weeks combing through some interesting threads. Like other forums I am on, we all love pictures so here is my new toy.
I picked up this little project from a friend of mine who has owned it for about 17 yrs. He had a built stroker motor in it for a short time and chopped the original cab many years ago. The cab ended up getting replaced after a few failed attempts of trying to cut windshields down. Personally, I am glad it got ditched and back to a regular top. He put the truck on air bags many years ago and as you can see it will not lay the frame but it is low enough for me, I have always been a static drop guy so this is a first in my court. Since the frame will not lay this gives me a sense of security in case of a system failure happening on the road. Future plans are to do the dreaded SWB conversion and try and duplicate cutting the bed as another member recently posted by rolling the front edge instead of welding. This will be the fourth frame cut friends and I done over the years.. New upper and lower stainless will be added to the body lines and I am going to un-shave the handles and key locks along with the front marker lights (not seen in pics) The truck is complete and I worked the deal to include the big block. Still looking for a TH400. Probably end up with a set of 20” wheels on all four corners. This will be a slower build than my others but should be just as fun. Right cab corner and rocker has been replaced, just need to start on the left side. |
05-24-2015, 08:41 AM | #2 |
Re: New Member Texas
Looks like a good start, i'm in.
84 step side 87 swb |
05-24-2015, 07:16 PM | #3 |
great project! that thing has some potential, glad the cabs got switched too....
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
05-27-2015, 11:47 AM | #4 |
potential indeed
* Call me NOT the website number* Justin Novick (773) 303-8251 Sales/Support Entropy Radiator / Engineered Cooling Products "The Sexiest Radiators For The Sexiest Hot Rods" - www.EntropyRad.com www.speedcooling.com |
01-11-2016, 06:49 PM | #5 |
Well as I mentioned before, it was time to give it a try. Using 65standard's idea and measuring twice before cutting, I was able to duplicate the bed cuts. From removing the bed and completely disassembling it to modifying the parts and reinstalling one side for test fitment I have about 11 hours into this project. I will not say it is an easy task but he has done his homework and spelled it out for us. If you follow his direction you can have a shorted if you chose to. A big THANK YOU goes his way for showing another way to do this with less body work in the end. I made a few mistakes along the way but now know what to change on the other side. Enjoy the pics.
65standard's thread... http://67-72chevytrucks.com/vboard/s...d.php?t=667694 BigJ |
01-11-2016, 06:52 PM | #6 |
few more pics from this weekend's thrashing.
BigJ |
01-12-2016, 12:48 AM | #7 |
Nice to see someone else giving that method a shot, turned out great!
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
01-12-2016, 11:06 AM | #8 |
01-12-2016, 11:39 AM | #9 |
Glad you were able to go back to original cab too.
In in. Sub'd |
