Old 05-24-2015, 10:54 AM   #1
one3n3my
No longer starting
The truck was running fine after it was rewired with a painless wiring harness. Then it started running and then cutting out after a few minutes which I thought could be due to the fuel sending unit and the mechanical fuel pump. I replaced both of those but now its not even turning over. Had the starter tested but the test said it was fine. The fuel pump fuse keeps blowing but have no idea where to go from here. Any help would be appreciated.
1970 Chevy C10
one3n3my is offline   Reply With Quote
Old 05-24-2015, 11:56 AM   #2
fat dan
Keep on Trucking
Re: No longer starting
Recheck all connections at ign. switch, starter solenoid, and battery. Is your battery good? You may have a bad ground, so recheck all of your ground connections.
fat dan is offline   Reply With Quote
Old 05-24-2015, 01:18 PM   #3
leftybass209
leftybass209's Avatar
Where is your fuel pump fuse wiring hooked to? The only wiring for the sender should be for the fuel gauge and it originally never had a fuse as it's not powered.
leftybass209 is offline   Reply With Quote
Old 05-24-2015, 02:53 PM   #4
one3n3my
The fuel pump wiring was hooked up to the fuel sending unit for the tank, which is still located in the cab. I'm going to check the maxi fuse but I'm kinda of at a stand still with where to go from here.
