Old 05-25-2015, 06:18 PM   #151
lower50's
lower50's's Avatar
Re: My 52 GMC Build
I started to make the intake hat out of the old air cleaner. I can't believe how much restriction there was from factory. Glad I'm cutting that out!!
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 05-26-2015, 09:00 PM   #152
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: My 52 GMC Build
I've cut out a lot of those in my day.
Ryan
1969 Chevy milk truck
Old 05-27-2015, 06:03 PM   #153
lower50's
lower50's's Avatar
Re: My 52 GMC Build
So the mail man was my friend today. Got my new waist gate actuator. It has a 7 psi spring in it, so I can start off running 7psi till I work the bugs out. Then I can tune it to 15psi. The factory one has a 19psi spring. I'll have pics tomorrow of intercooler mounted, intake hat and actuator.
1951 MG TD
Old 05-28-2015, 03:35 PM   #154
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Today I got my inter-cooler in and hooked up.
First pic is looking where the rad should be.
Second pic is the intake hat that I made.
Third pic the 3" hose I'm using. It should work it's rated at 230* and 30 psi. I don't think it looks to bad.
1951 MG TD
Old 05-28-2015, 04:28 PM   #155
05snopro440
05snopro440's Avatar
Re: My 52 GMC Build
Attachment 1408695
Attachment 1408696
Attachment 1408697
Attachment 1408698
Attachment 1408699
You're getting there! It's looking cool!
Just my unsolicited opinion, but I don't like the flexi hose for the turbo outlet to the intercooler is a good idea. Since you're planning on cranking up the boost, your turbo outlet temperature could end up very close to the 230°C limit of that hose, but you may also get extra heat transfer from the engine bay to the air in the hose. I guess my point is, do you want to take the risk of melting the hose and feeding dirty air into the engine? I think solid plumbing would not only work better, but would be safer and perform better. Just one opinion.
My 455 Buick powered '46 GMC Build Thread
My '46 GMC on Photobucket
05snopro440 is offline   Reply With Quote
Old 05-28-2015, 05:07 PM   #156
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Thanks. I am wondering about that happening. I'm not going to run solid right now there are a lot of bends to get where it has to go, I think it would be all cuplers. I cant weld aluminum. I'll see what temps I get with my inferred gun. I found some flex silicone hose, but really expensive. So I guess this is just for now.
1951 MG TD
Old 05-28-2015, 05:17 PM   #157
05snopro440
Re: My 52 GMC Build
Yeah, when I said solid I meant just straight lengths with couplers. What I saw in my mind looked nice and clean. For what it's worth I've seen and heard that you can buy good quality silicone couplers online significantly cheaper than at your local auto parts store, especially for us Canadians.
Old 05-28-2015, 05:44 PM   #158
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Thanks a lot!! That's the way I would really like to go. I'll do some searching and change it out before I really start driving.
1951 MG TD
Old 05-28-2015, 06:25 PM   #159
Dieselwrencher
Re: My 52 GMC Build
Nice work. I as well, don't think that type of hose will work for you either. Something tells me if it doesn't rip, it'll just blow apart. Thicker type stick hose from a heavy truck shop may work decent though. I try not to use any long hose on intake systems because it's hard to keep them on. At 15psi you won't have as many issues, but the vlume of air going through the pipes has a lot to do with it too.
Ryan
Old 05-28-2015, 07:49 PM   #160
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Thanks for the feed back Dieselwrencher. It is industrial, coated nylon hose but, it is on my small list of things to redo.
1951 MG TD
Old 05-28-2015, 08:18 PM   #161
Dieselwrencher
Re: My 52 GMC Build
It'll work for now at least. When you go to build piping, you could rotate the hx35 towards the fender well and just go through there and save a couple bends?
Ryan
Old 05-28-2015, 08:36 PM   #162
lower50's
lower50's's Avatar
Re: My 52 GMC Build
I'll look into that but I don't think there is room with the tire.
1951 MG TD
Old 05-29-2015, 03:38 PM   #163
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Finally got my fan today. 16" 1918 cfm. H.O. extreme, it is a really high cfm. So mount that on the rad brackets tomorrow and install rad, rad hoses, coolant. Turned over motor today to get oil pressure from sitting for a year. Then a bit of wiring (glow plugs, fuel pump) and If no problems start it up tomorrow!!!!!!!!!!!!
1951 MG TD
Old 05-29-2015, 05:46 PM   #164
99 to Life
99 to Life's Avatar
Re: My 52 GMC Build
dang, you make it sound so easy!
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 05-29-2015, 05:53 PM   #165
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Not easy but it helps I have no ignition.
1951 MG TD
Old 05-29-2015, 09:14 PM   #166
Kodiaks53
Re: My 52 GMC Build
I see you got the fan, tomorrow should be a great day!
Kodiak's 53S10 Build
Kodiaks53 is offline   Reply With Quote
Old 05-30-2015, 12:16 AM   #167
Dieselwrencher
Re: My 52 GMC Build
That's an awesome fan man! You can't mistake the sound of an IDI cranking over! One of my favorite sounds from my early diesel days.
Ryan
Old 06-01-2015, 07:23 AM   #168
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Well Saturday was a great day. Got fan mounted rad installed and filled took 19.5 liters of coolant. Did a bit of wiring, so I can sit inside to start the big beast and vroom
It sounds just like I was hoping (GREAT)
http://youtu.be/4T4BF_z7Dtk
-fan install
-Waste-gate actuator
-Me checking motor temp. Ran motor for about half an hour.
1951 MG TD
Old 06-01-2015, 09:29 AM   #169
99 to Life
99 to Life's Avatar
Re: My 52 GMC Build
that thing is a beast, so much torque. Congrats, first starts are so fun.
Old 06-01-2015, 09:50 AM   #170
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Thanks 99. 360 ft-lb is stock N/A
1951 MG TD
Old 06-01-2015, 12:31 PM   #171
Advanced Design
Advanced Design's Avatar
Re: My 52 GMC Build
That sounds scary awesome! Great fab work too. Really enjoying tagging along.
Advanced Design is offline   Reply With Quote
Old 06-02-2015, 07:02 AM   #172
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Thanks AD
1951 MG TD
Old 06-02-2015, 01:37 PM   #173
oossuuu754
oossuuu754's Avatar
Re: My 52 GMC Build
Just loving this build more and more. Love the visual with flexible induction hoses that appear to breath with the motor. If you haven't named this monster yet, I thinking "BANE" would be a good choice for this big beast.
---Shawn
Cecil-1953 5 window build thread
Skymangs..Chris of Old Sarge customs had a shop fire and was severly injured. To help with the medical bills and expenses a fund has been set up here....http://gofundme.com/c49h5mjx8 More details are here...http://67-72chevytrucks.com/vboard/s...=1#post7253189
oossuuu754 is offline   Reply With Quote
Old 06-02-2015, 09:06 PM   #174
Dieselwrencher
Re: My 52 GMC Build
It sounds awesome! Be careful when you shut the hood and lay on the skinny pedal. With how much rise you're getting out of your charge air hoses, I could see a new dent in your hood.
Ryan
Old 06-03-2015, 12:03 AM   #175
shopteacher
Re: My 52 GMC Build
Great Video! The Beast is Alive !
shopteacher is offline   Reply With Quote
bagged, build, diesel, gmc, hot rod
