#1776 | |
Re: Make it handle
http://67-72chevytrucks.com/vboard/s...=my+castor+mod
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
#1777 | |
Re: Make it handle
Here's what I've put together with help from this thread. I'll be starting on the rear soon, I'm leaning towards a three link and a floating 9". ![]()
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
#1778 | |
Re: Make it handle
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
#1779 |
Re: Make it handle
Looks like the ball joint came inside a bit as well. Interesting. How does that affect angles?
#1780 |
Re: Make it handle
I did move it in just a hair. I don't like having a ton of spacers on the UCA so this should remove a few when I get it aligned.
I will result in slightly less camber gain when the suspension compresses. I am not looking for the ultimate performance so I am not too concerned with it.
#1781 |
Re: Make it handle
Rob,
Just wanted to let you know that fitted your from and rear ARB's and Doetsch shocks and have to say the transformation is phenomenal! EArlier in the thread you mention boxing and bracing the chassis, could you elaborate slightly on the bracing? Having difficulties visualising where the cross bracing goes. Also... Your customer service is to be recommended, thanks for sorting out the short shipment so promptly and apologise for not thanking you earlier. P. ![]() |
#1782 |
![]() Join Date: Oct 2012
Re: Make it handle
HI, I have a question, i have read some of the 70 plus pages here,
But my question is, have you guys found the limit to the 12 bolt rear axle with c clips, how much HP and Rear tire will it hold in a G type of set up? 6.4 500hp hemi
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9 |
#1783 |
Re: Make it handle
this thing goes pretty good now and i don't drive slow, i hit the canyon pretty good. stock suspension with air bags and 1 1/4 front sway bar. disk up front
29/15/15 rear tires, Viking double adjust shocks in the rear kyb up front. I fear wheel studs might break and my rear tire and rim will pass me, or the c clip tip will break and the same thing will pass me......
#1784 |
Re: Make it handle
I know this guy is running the stock rearend with a supercharged 406 SB with nitrous. He carries the Dyno printout with him at the car shows and claims he is past the 800 HP mark with a single hit of NOS. He's more of a straight line kind of guy though, I don't know if he's into driving the curves. There are several companies now that offer direct replacement 9" and Dana 60's. Currie and DTS (Drive Train Specialists) are a couple.
#1785 | |
Re: Make it handle
question is: can I set the upper A-arms back with in the stock adjustment range ( threads showing on the rear of the shaft) to get additional caster ? ---OR--- does it NEED to be centered??? $2k for ridetech A-arms and coilovers just isn't in the budget at this time. I spent all my $$$ at NLE! Last edited by Bowtiguy; 07-14-2015 at 12:22 PM. |
#1786 |
Re: Make it handle
https://www.facebook.com/interesting...nch_main_video
it is not a truck suspension but most of the info can be used to understand basic suspension. they are already explained in the thread but it doesn´t hurt to watch.. |
#1787 |
Re: Make it handle
Has anyone tried rear springs moog 6381. They have a free length of 14.34 a spring rate of 198lbs.
#1788 | |
Re: Make it handle
1968 LWB C20 / AC / Wood Bed |
#1789 |
Re: Make it handle
New to the site. Just bought very nice 70 swb frame and running gear.
I removed the cab and box brackets prior to frame sand blasting. I've gotten good at removing rivets! I'm going to lower it most likely 5/3.5. Question. Is it any benefit to the track bar frame mount a bit forward so it's more perpendicular to the rear end? I know I will need a new longer adjustable panhard bar. Thanks |
#1790 | |
I'm just glad to be here!
Re: Make it handle
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#1791 | |
Re: Make it handle
I think he is taking about something like these: Since the "legs" are welded to the boll joint mount, that end cannot pivot to change the angle at that corner of the triangle. They can be adjusted to a point before the ball in the rod end binds up, they are limited to the angle of defection of the ball in the rod end. Once it binds up, then the leg will need to be heated and bent to fee up the rod end... ![]() ![]() Since the "legs" are welded to the boll joint mount, that end cannot pivot to change the angle at that corner of the triangle. They can be adjusted to a point before the ball in the rod end binds up, they are limited to the angle of defection of the ball in the rod end. Once it binds up, then the leg will need to be heated and bent to fee up the rod end...
#1792 |
Re: Make it handle
Thanks for the reply. Looks like I will continue to drill more rivets.
Another question. I've been looking at Mike Hickmans C10 build in regards to frame bracing. Looks like he did a far amount of X-bracing as apposed to frame boxing. Also welding triangular plates across stock cross members. Any opinions? Good or not. Thanks |
#1793 | |
Re: Make it handle
There are several products out since, such as the Porterbuilt Inner Frame Stiffener ( http://pbfab.com/shop/inner-frame-stiffener ) that really helps to get a head start on fabricating. I wish these were available at the time I built my truck! It may seem expensive at first, but when you figure up material cost, fab and engineering time saved, it's a pretty economical piece. |
#1794 | |
Re: Make it handle
![]() I still have quite a bit to add to it. I did a SFBD on mine but if I hadn't I would really consider going with Porterbuilt. I will have less money into mine but the amount of time I put into it would make Porterbuilt's cheaper (and of course theirs is much nicer).
#1795 |
![]() Join Date: Aug 2014
Re: Make it handle
Is there a noticeable improvement in handling by diong a 4 link as compared to running the stock trailing arm setup on a 70 c10 and relocating the shocks/adding an aftermarket panhard rod?
I'm having trouble trying to decide which route to take. I'm planning to get the no limit rear rail kit and wide ride IFS up front. Just don't want to go totally broke getting the suspension/brakes dialed in. I know I could save substantially by re-using the stock differential, as it would likely be easier to just upgrade to a moser 9" when running the 4-link. Anyone have any experience with going this route? |
#1796 |
![]() Join Date: Jun 2006
Re: Make it handle
Hi Rob,
So after reading much of the thread most of it is dedicated to the later model 67 up trucks. I recently finished the paint and body work on my 1965 GMC Longbed 3/4 ton truck and while I do not plan to race it I want it to handle better than it came from the factory. I plan to keep the 8 lugs since its a money issue [already have 18"x8.5" wheels with 265/60/18's] and I have other bills. I will be swapping the front drums to the 8 lug rotor conversion [3" Drop spindles] that POL sells and using a hydroboost setup. I know about weight removal and relocation, it had two saddle tanks and the one behind the seat. All three are gone and I'm adding a 32 gallon custom built tank to it behind the axle. So part of my question is which front springs should I get since I'm switching to a 500HP 5.3L LS from the obscenely heavy 305E V6 and I really don't want to do a flip kit to drop it but I wouldn't mind the truck being more level than the stock trucks are. Should I get rid of the stock multi-leafs for a new lowered set? I still might haul light loads under 1000 pounds in it rarely. 1 1/4 inch front sway bar? 1 inch rear or bigger? Its overall weight will be much lighter than stock with all the aluminum parts and I plan to set the motor back as far as I can and still remove the valve covers if need be. I also plan to run two batteries mounted in the rear outside the frame rails behind the tank and a roll pan/custom 4"x6" pipe bumper. Someone mentioned Cal tracs and there is a new solution that's more adjustable but both seem meant from leafs under the axle not over it. Can I build something similar to the style available for the earlier trucks [55-59] ?
Custom Painter/Restoration Specialist 1965 GMC 3/4 Ton LB SOLD? 1964 Chevy El Camino in full restoration 1991 Chevy S10 288K+ miles 2nd Owner SOLD 2020 RAM 1500 Warlock |
#1797 | |
motor exploder
Re: Make it handle
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! |
#1798 |
Re: Make it handle
Great job on that frame it looks just perfect.
#1799 | |
![]() Join Date: Jul 2010
Re: Make it handle
GoodGuys 2012 Pro-Truck Champion ![]() 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion ![]() 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion ![]() Proud to put our products up against all others! |
#1800 |
Re: Make it handle
Looks great. How did this effect the ride/handling of the truck?
