Old 05-26-2015, 04:53 PM   #1
steve aleve
Trans Tunnel: To be removable or not?
I am working on a 55 1st series on an s10 frame with a Vortec 5.3 and 4l60E. I have had to cut the floor and firewall for a trans tunnel and I planned on making it bolt in (in case I have to access the transmission or for easy access to unbolt the trans if I have to replace it.) It seems a lot easier to just weld it in and deal with the trans access later. Thoughts? Anyone doing it one way or the other?
steve aleve is offline   Reply With Quote
Old 05-26-2015, 05:47 PM   #2
yossarian19
Re: Trans Tunnel: To be removable or not?
You had to cut floor & firewall?
You must be slinging it further back than I have mine...
I'd just weld it in. It's not hard to pull radiator & grill off of these trucks & yank the powertrain as one big piece.
Alternately, drill undersize holes in the floorboard and firewall & clearance holes in the trans tunnel and use sheet metal screws. A #12 should do.
"Over my head"
1957 Chevy 3200, big rear window & 6 lug.
Front disc, power steering, Vortec 4.8 / 4L60E swap, hydro boost brakes & patina.
yossarian19 is offline   Reply With Quote
Old 05-26-2015, 06:54 PM   #3
steve aleve
yossarian, thanks those are both good options. I do have the engine pretty far back and it sits pretty high as well. Not to mention I am mounting the cab very low.
Old 05-26-2015, 07:09 PM   #4
Sim6
Sim6's Avatar
Steve, do you have a build thread for your swap?
1969 Chevy C10 SWB 350/400 4"-6" drop on steelies
53' Chevy 3100 5 window http://67-72chevytrucks.com/vboard/s...d.php?t=660793
http://67-72chevytrucks.com/vboard/s...d.php?t=771679
Sim6 is offline   Reply With Quote
Old 05-27-2015, 11:02 AM   #5
steve aleve
I do... but it is far from updated. I need to find more time!!! I can barely find time for the build lol. Hopefully I can get a chunk of time to update so that everything is current.
http://67-72chevytrucks.com/vboard/s...d.php?t=648779
Old 05-27-2015, 12:05 PM   #6
Chevy-49
Chevy-49's Avatar
thanks, same question crossed my mind yesterday.
have a lokar trans mount shifter and hand brake,
access from above is help full although one piece carpet is not possible.
My build thread: 1949 AD truck 'Chevy-49'
Chevy-49 is offline   Reply With Quote
Old 05-27-2015, 11:13 PM   #7
HUSSEY
HUSSEY's Avatar
I was planning on doing the same thing myself. I was thinking of making an insert that looked something like this:
http://www.progressiveautomotive.com...3/02/CV225.jpg
I was going of flange the firewall like the floor and making it removable.
My 49 AD Build / S10 Chassis -- Thread -- Pictures -- S10 Conversion Mounts
HUSSEY is offline   Reply With Quote
