05-28-2015, 12:26 PM | #26 |
Re: 60-62 V-8 auto crossmember
So the hydramatic was only behind the v 6
The powerglide was only in chevys until 63, and then in gmc's but still not behind the v6 There are 2 different widths, one for lwb and one for swb. Thers is a straight type and dropped down type possibly for high or low hump cabs. Did sombody over at ford design this ? |
05-28-2015, 02:10 PM | #27 |
I did look a little further and it does state that the V6 was the eng used, but there was a 248,270 and a 392 cu in I6 US production eng as per this link
http://home.znet.com/c1937/Cast.htm I am curious a to if the P series had the x member and if it could have used a p/glide in the lighter models/ Canadian production GMC did use the p/glide in those years bhind the 235/261 engs ron |
05-28-2015, 03:06 PM | #28 |
Reading from the 1960 GMC Data book , yes a 270A they call it, was available in the "1001 Junior Van RPO" and it states for transmission SM-318 three speed" with no option of anything else. No listing for any larger vans except the cowl/body . All GMCs 1000-5000 were 305 v6 base engines till 4000 was optional with 351 . No mention in the transmission section of what models came with what. Maybe later 61 or 62 had different in-line 6s ? Don't know. Last mention of auto trans is 2500 series. No mention at all on powerglide in the transmission section , just 4 different models of turbo-glide.
Canada ?? I have no idea or have no info on. Anyone have 1961 1962 and later GMC Data books they would part with ?? Looking for more.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
05-28-2015, 04:12 PM | #29 |
Going to through this out there for what its worth. 6 parts books later , the part number shows up in the 1960 parts book, C10 115 WB 3768509 , then parts history change in 1961 to 3787122 , that number is listed then as the replacement for 1960 and correct number for 1961-1962. Same for 1960 part # 3768510 Series 10 and 20 127 WB changed to 3787123 for now 1960-1962.
Can only guess one drop is early 1960 and the other 1961-1962 unless theres a part number stamped in one which I doubt ? No listing at all specifically for Van, but theres an interesting note for 3787122 1960-1962 W/102 and W/115 WB ?? What is 102 wheel base ? Chevy Van ? More digging ! Also none of these part numbers show up in GMC books , Just Chevrolet USA books.
05-28-2015, 04:26 PM | #30 |
Powerglide was in GMCs 1963-1966 behind the V6 with an adapter .
05-28-2015, 10:29 PM | #31 |
1960chevypanel, Thanks for posting the dimensions.
Here is a crossmember that came out of a Buick. Pretty close and I thought It would fit my 61 Burb. I still have not mocked it up between the frame but it did look like it might fit. Seems a bit shorter on the top length. Here is the info on it's application if anyone is interested. "This is a used transmission cross member out of a 1964 Buick Wildcat. This cross member is in great good condition. This car had the ST400 transmission in it. This will also fit a 1964 Buick LeSabre and Electra 225."
MusicMan70 1961 GMC Suburban |
05-28-2015, 11:17 PM | #32 |
those were the aluminum p/glides and were called "at-218 pow0r-flow which was the GMC word for p/glide
60-62 would be the cast iron p/glide. that 102" wb may have been a mail type delivery truck and may have utilized a small I6. in 63 they came out with the 194 cu in eng. it is amazing how much GMC info is missing ron |
05-29-2015, 01:32 AM | #33 | |
05-29-2015, 01:42 AM | #34 |
Dug out a long bed auto cross member, I never noticed it has a drop also. It's from a 1961. Here are some pics comparing it to the short bed drop member:
