Old 05-28-2015, 12:59 PM   #1
bigscooter
would 373s work for this?
hi guys, i can't stand this low geared rear end any longer(456s probably). it's a '91 r3500? 2wd crew cab. it is a small block, the tranny is the manual with the low and 3 speed. my rear end is not dually. I'm hoping 373 gears won't be too high. i value economy more than strong hill climbing. i don't tow more than 5k (usually just motorcycles and VWs around town). i do dream of some day installing a 5-speed. Am i barking up the wrong tree?
Thanks!
bigscooter is offline   Reply With Quote
Old 05-28-2015, 02:01 PM   #2
mrolds88
Re: would 373s work for this?
I don't think you're barking up the wrong tree. I believe you'll do just fine. Especially with the manual. The low 1st gear will help out with that. When you do go after a rear. Take a tape measure with you. And note where your shock mounts are. IIRC the 3/4 an 1 tons are different. Same rear just different mounting locations.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 05-28-2015, 03:08 PM   #3
wilkin250r
wilkin250r's Avatar
I would suggest that your first order of business is to determine what you currently have. There are a couple methods.
You could drain the fluid, pull the cover, and count teeth (most definitive method).
Or you could jack the wheels off the ground and spin them while counting driveshaft rotations, but if you use this method you have to make sure both wheels turn the exact same amount, OR leave one on the ground and spin the other twice.
Once you know what you have, you'll know what you're up against. If your 4.56 turns out to actually be a 4.10, changing to a 3.73 won't be all that significant.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!!
wilkin250r is offline   Reply With Quote
Old 05-28-2015, 04:06 PM   #4
Bigstevex4
Bigstevex4's Avatar
if you have 456s you would be turning 4 grand at 75 most likely 410s or 373 and 373 is low not high unless your running 38s. And what he said above.
83 c10 long Box Daily Driver
90 Jimmy parked
98 Road King/ 06 Road Glide
In memorium
63 impala SS/ 65 Chevy Panel
65 GMC Short Box/ 68 Camero
Bigstevex4 is offline   Reply With Quote
Old 05-28-2015, 04:42 PM   #5
mongocanfly
mongocanfly's Avatar
Mine has 4.10 gears which I like for towing so I went to a nv4500 5 spd...it doesn't have the exact gear ratios the 4 spd had but the overdrive sure is nice. And keeping the 4.10 is even nicer..I still got low gears to get loads moving and overdrive to keep the engine rpms down. But a 5 spd swap is more expensive than a gear swap. And like stated 3.73 and 4.10 is not much difference. I have been told if you do the math that the ratio difference between 4.10 and 3.73 is about the same difference as the o.d. difference of a new set of tires vs. a worn out set.
Old 05-28-2015, 06:27 PM   #6
greg64
greg64's Avatar
How tall are your tires? Or, failing that, what's the tire size? Then we can work backwards to figure out a suitable rear gear ratio for a reasonable engine rpm.
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
Old 05-28-2015, 07:41 PM   #7
bigscooter
i have the cover off now and i cant see any markings on the gears. i can't see the pinion well enough to count the teeth. my tires are 32" tall, at 50 mph it's at 2300 rpm though.
Old 05-28-2015, 08:06 PM   #8
Jake Wade
Jake Wade's Avatar
Based on the information you provided, 3.73's would drop your RPM at that speed by approximately 400 RPM and 3.42's approximately 600 RPM.
Jake Wade is offline   Reply With Quote
Old 05-28-2015, 08:50 PM   #9
v30crewcab
v30crewcab's Avatar
theres numbers stamped on the outer part of the ring gear. also you can look at the numbers in the glovebox and find the diff code and check that way.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 05-28-2015, 09:44 PM   #10
TwoFiftyShifter
2300rpm at 50 could be either 4.10 and 4.56. Need to pull the cover to know for sure. My 87 V20 was a 350 4 speed stick and 3.42s... Pretty good ratio. 2500 at 65.
1982 K10 SWB
1987 V20 - Sold - Doh!
TwoFiftyShifter is offline   Reply With Quote
Old 05-29-2015, 04:14 AM   #11
bigscooter
I wondered what those numbers were about. Looks like code HC4 is 4.56.
Old 05-29-2015, 12:11 PM   #12
bigscooter
I'd like to do 70ish mph at 2300-2500 rpm. with this size truck, am i dreaming?
I do have a lowering kit for it. if 3.73 is too sluggish maybe i could run smaller tires?
Old 05-29-2015, 12:48 PM   #13
mongocanfly
3.73 would be ok..my 4.10s with 5spd will run 70 all day long.
Old 05-29-2015, 07:36 PM   #14
wilkin250r
wilkin250r's Avatar
3.73 will not be sluggish. It might even be still a tad low, but not unreasonably so. I'm running 3.73 with an inline 6 right now (5spd), a 350 could easily pull taller gearing, especially with the low first gear to get loads moving. And according to my calculations, 3.42 would put you at 70mph, 2500rpm.
No doubt that 3.73 will work just fine, but I think you could go 3.42
Old 05-29-2015, 07:54 PM   #15
Jake Wade
Jake Wade's Avatar
You want 3.42's
Old 05-29-2015, 09:02 PM   #16
v30crewcab
v30crewcab's Avatar
yep without overdrive 3:42's is the best.
71 longbed 5.3 4l80
Old 06-01-2015, 03:03 AM   #17
bigscooter
I'm hoping to find a complete rear end to swap out. I'm likely to find a 3.73. a 3.42 might be a tough find in my configuration.
