Old 05-28-2015, 01:04 PM   #101
GRADYS Performance
GRADYS Performance's Avatar
Re: 4BT Cummins 4L85 Long to Short
Very nice project with well thought out work and details.
GRADYS Performance is offline   Reply With Quote
Old 05-28-2015, 05:20 PM   #102
hick
I just realized that I will never amount to any thing in life after looking threw this... Cause this is my dream build.
Its disappointing to hear about your mileage. I would have expected more.
Does the insulation help quite a bit? I enojy the knock of a cummins as much as the next guy, but I enjoy a stereo that doesnt need to be cranked all the time as well
1989 3+3 2wd Dually. 454 BB. Factory loaded for the day, including Alcoa rims.
hick is offline   Reply With Quote
Old 05-28-2015, 07:33 PM   #103
bowfaber
bowfaber's Avatar
I was extremely disappointed with the mileage. I was hoping for nothing less than 25 mpg. The first few tanks was 18-19 mpg. I trimmed the shift points, lowered the TC lock up, and didn't drive it like I was 16 and got 23.4 mpg. I built it to be a nice driver with good mileage. It has good road manners but wish it was north of 25 mpg. I will put a taller tire on the rear and let you know what happens.
Without all of the dynamat I couldn't drive it without earplugs. Drove with Ma'Lady on it's maiden voyage to a drive in movie. We both wanted to throw up after the trip because of the noise and vibration. That's not a problem now. My main problem now is the wind noise coming through the windows and doors. I hear some engine noise but it's fine. I hear the turbo whistle a lot more.
bowfaber is offline   Reply With Quote
Old 05-28-2015, 08:06 PM   #104
sodly
sodly's Avatar
Just curious.... what did you do with your original wheels/tires?
WANTED:
* 60-66 Chevy and GMC FACTORY PHOTOGRAPHY (scans) of pickups and carryalls.
Custom Camper Club-- Own a 65-66 Custom Camper? Join us at: http://67-72chevytrucks.com/vboard/g...hp?groupid=117
sodly is offline   Reply With Quote
Old 05-28-2015, 08:43 PM   #105
bowfaber
bowfaber's Avatar
Still holding up the long frame.
Old 05-28-2015, 08:52 PM   #106
bowfaber
bowfaber's Avatar
Old 05-29-2015, 07:46 AM   #107
BigBlockBurris
BigBlockBurris's Avatar
AWESOME build, and thank you for sharing!
Two questions.
1-Where did you get your motor mount rubbers? I know you fabricated the metal part, but what about the rubber isolators?
2-What exhaust is that?
Thanks!
BBB
BigBlockBurris is offline   Reply With Quote
Old 05-29-2015, 08:41 AM   #108
bowfaber
bowfaber's Avatar
Rubber isolators came from the step van. They were the factory mounts. I did some research on this topic and found these isolators were one of the best ones to use because they dampen the vibration good, and I already had them- bonus!
Intercooler tubing came from Frozen Boost. I went to JEGS and got some 3 inch stainless 90, 45, 30, 180 bend (Tip- buy 180s, you can cut them in half to give you two 90s for less money.) Started cutting and fitting the pieces until it was how I wanted it. Welded them up and ground off the welds to make it appear seamless. 4 1/2 inch wire wheel finish. The turbo down pipe required a tight radius 90 which I got off Amazon. I cut the v band off the factory down pipe and welded it to my new stainless piece.
Old 05-29-2015, 12:13 PM   #109
Luther Grimace
Luther Grimace's Avatar
Wow this is a great thread! Very impressive. I may have missed it but did you address what you are doing for a controller for the 4L85E? Also did you TIG weld all your hot and cold side piping? It looks great.
Also I can't believe this truck doesn't get closer to 30 mpg. My 4x4 6BT will get 20-22 mpg on highway trips. What is your cruising rpm with the 3:08 gears? And is your lockup working in the trans?
1955.2 Chevy 3100, 6bt, Getrag G360 5-speed, NP205, Dana 60/70 - http://67-72chevytrucks.com/vboard/s...d.php?t=536540
1992 Chevy K1500 Silverado ECSB
1965 "Crewcab" Chevelle 300 Deluxe - soon to be LBZ Duramax/4L85E powered
Luther Grimace is offline   Reply With Quote
Old 05-29-2015, 12:51 PM   #110
bowfaber
bowfaber's Avatar
[QUOTE=Luther Grimace;7190378]Wow this is a great thread! Very impressive. I may have missed it but did you address what you are doing for a controller for the 4L85E? Also did you TIG weld all your hot and cold side piping? It looks great.
Every weld on the project was tig welded with a miller dynasty 200dx except for the box, rust repair, trailer hitch, and air bag mounts.They were welded with a miller 350p and miller 141.
Trans controller is a simple shift. It came with adapter plate from PATC.
The TC lockup is engaging. It likes 55-60 mph. At 60 it's running anywhere between 1640-1820 rpm depending on the incline.
Old 05-29-2015, 01:46 PM   #111
68Gold/white
Look'n Good!!!
68Gold/white is offline   Reply With Quote
Old 05-31-2015, 08:26 PM   #112
bowfaber
bowfaber's Avatar
truck
Old 07-01-2015, 11:45 AM   #113
deejaaa1
i'm only on page 2 but want to respond before i lose my thought.
your fab skills are top notch. love the redneck dent puller.
have you used the Tite seal over any long periods? does it hold up to weather? i've used some in the past but it seemed to be no more than a rubberized spray that washed off when it rained.
deejaaa1 is offline   Reply With Quote
Old 07-01-2015, 04:55 PM   #114
deejaaa1
edit: finished the thread. awesome build. GLWS.
Old 07-03-2015, 11:16 PM   #115
bowfaber
bowfaber's Avatar
The Titeseal works great in the cab, and good under the truck. It seems to hold up better when it's painted. If it sees a lot of sunlight it gets weak and will come off easy. I drive a lot of gravel roads so it gets some good abuse. One place on the rear cab support gets a lot of rocks thrown at it and the product is gone. My next build I will try a rhino bed liner on the underside, if it's visible under the hood (like my firewall) it will have Titeseal with paint. I like how it lays down, looks better painted, and it's not too rough looking.
Old 07-04-2015, 10:05 AM   #116
deejaaa1
thanks for the info.
Old 07-04-2015, 09:15 PM   #117
Heavy Evy
born to lose
Heavy Evy's Avatar
Wow all I can say is rad!
_____________________
'67 Chevy Belair Wagon 283 Powerglide
'68 Chevy II Nova 2 door 350 TH400 Sold!!
'71 Chevy C20 350 TH350
'71 Chevy C10 Burb 350 TH350 stolen totalled gone....
Burb Build
http://67-72chevytrucks.com/vboard/s...d.php?t=475155
Nova Build
http://67-72chevytrucks.com/vboard/s...d.php?t=498979
Wagon Build
http://67-72chevytrucks.com/vboard/s...d.php?t=543052
Not giving a truck.
Heavy Evy is offline   Reply With Quote
Old 09-16-2015, 08:16 PM   #118
Luther Grimace
If you don't mind me being nosey what is taking its place to go fast!
Old 09-16-2015, 08:17 PM   #119
bowfaber
bowfaber's Avatar
duramax I believe
Old 09-17-2015, 10:48 PM   #120
Luther Grimace
Doing the same thing myself. Have you found a donor truck yet?
Old 09-22-2015, 11:13 PM   #121
bowfaber
bowfaber's Avatar
I got married a month ago and the truck was the star of the show, 2nd place to my wife I mean...
Old 09-22-2015, 11:15 PM   #122
bowfaber
bowfaber's Avatar
My best man needed it a couple weeks later...
Old 09-23-2015, 01:58 AM   #123
Nitis
Nitis's Avatar
never ceases to amaze me at the skills and talent that some of you have I can dream up lots of stuff but could never act on it as you did.
I have dreamt of a similar build for close to 20 years now only difference is I would do a manual trans as I just have never cared for diesels with automatics
I am rather surprised at your mileage as well definitely throw a taller tire on there and stink bug it a little that should help
well played sir
Nitis is offline   Reply With Quote
Old 09-25-2015, 10:53 AM   #124
bowfaber
bowfaber's Avatar
Off to Minnesota
Old 08-21-2016, 02:32 PM   #125
bowfaber
bowfaber's Avatar
Re: 4BT Cummins 4L85 Long to Short Duramax Allison
Didn't care for the 4bt, so I shoved an LBZ Duramax and built Allison 6 spd into the ol girl.
