05-29-2015, 02:06 PM | #1 |
Six in a row makes it go...
Original long-step bed wood (used) *SOLD*
I bought a '67 long-step from the original owner. He had put a steel plate over the bed wood shortly after purchasing the truck. You can see the truck in the 67 C20 build thread in my sig line.
During restoration, I pulled that plate and saw the original paint on the wood. There is one hole, approximately 3/8" through one board where he had a bolt through. Apparently he did not want the 1/4" steel plate flying away. I was originally going to reuse the boards, so I washed the undersides and applied spar varnish to the undersides only. The paint job was coming out so well that the painter threatened to not finish the job if I didn't go with new wood. So I have the original southern yellow pine wood with most of the original paint on it and spar varnish on the underside. This ad is for the wood only. I'm asking $90.00 and I range down as far as CT sometimes so we may be able to work out something on delivery.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce Last edited by Shaky; 06-13-2015 at 09:24 AM. |
05-29-2015, 06:18 PM | #2 |
Re: Original long-step bed wood (used)
interested pm sent
05-29-2015, 06:19 PM | #3 |
that is a cool find!
you know them steel plates weigh a ton. i bet your rear suspension groaned in relief when you pulled it
1967custom |
05-29-2015, 06:23 PM | #4 |
I'll take em depending on shipping.
05-29-2015, 07:58 PM | #5 |
I'll get in line.
Thanks so much, Jake |
06-01-2015, 04:38 PM | #6 |
So far blap is first in line. I'll keep everyone posted to see if we transact in two weeks. Thanks.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
06-01-2015, 04:41 PM | #7 |
If still available after Jake I would like the next spot in line.
1969 Chev Longhorn Custom Camper 1955 Buick Century Estate Wagon 1963 Buick Riviera 1953 Chevy 3100 Panel 1967 C-20 V8 4 speed 1951 Willys Jeep Wagon 1956 Chevy Suburban |
06-01-2015, 04:42 PM | #8 |
Between the steel plate, spare starters and alternators, the air-horn contraption, and the metric-ton of grease and goo on everything; I'll bet the truck shed 500 pounds after I got it!
06-01-2015, 05:26 PM | #9 |
you oughta name your truck "Jenny" after jenny craig!
1967custom |
06-13-2015, 09:25 AM | #10 |
SOLD. Glad to see those slats going to a good home. Thanks blap!
06-13-2015, 07:25 PM | #11 |
Thank you for making the trip down!!!!!!
Great to meet ya best of luck with your build! |
