Old 05-29-2015, 03:55 PM   #76
Clyde65
Clyde65's Avatar
Re: 1966 custom camper & alaskan camper survivor
If!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 05-30-2015, 04:48 PM   #77
Chevystep
Originally Posted by murdoc View Post
Thanks for posting! Have you been happy with your Alaskan camper since the restore? Was it worth all the effort? I have been weary about restoring mine. Mostly because of the weight of it too. The thing has got to weigh at least 2,000 lbs, probably more since it is a 10 footer.
Oh yeah, it's a great little camper. I put it on my 3/4t Dodge about 5 times for camping, now I've got a hold of a little dual wheel utility trailer I take it on and off of. Two folks for a weekend is a great time, or a deer camp trailer on battery power. The real scary part on truck bed mounting is how high you have to lift the thing to slide the truck under it. I mounted 4 aftermarket RV top screw lifts on it but it was still a nervous time lifting the thing up to truck bed height. Resto wasn't too bad since I really only did the top half, just pulled it all the way off and redid the ends, stringers and new metal skin. Added some bulk to the stringers for a small roof A/C and completely epoxied the two lowest stringers (the originals were pretty rotted) and re skinned the inside with 1/8" oak panels. If you've got the original brass hydraulic rams, just new O rings will fix them up. You're probably not too far off on the weight, it's a bunch.
Chevystep is offline   Reply With Quote
Old 05-30-2015, 08:44 PM   #78
Chevystep
Hey, if you get around to pulling that horn ring off, I'd love to see what it looks like under there. I have an original ring like that without the center emblem (I think!?) and would like to know how it all went together on the wheel, I'd like to try to put an old bowtie center horn button emblem in it somehow....
Old 08-18-2015, 11:25 PM   #79
sodly
sodly's Avatar
Any progress to report, murdoc?
WANTED:
* 60-66 Chevy and GMC FACTORY PHOTOGRAPHY (scans) of pickups and carryalls.
Custom Camper Club-- Own a 65-66 Custom Camper? Join us at: http://67-72chevytrucks.com/vboard/g...hp?groupid=117
sodly is offline   Reply With Quote
Old 10-07-2015, 02:26 PM   #80
murdoc
murdoc's Avatar
Sorry for taking so long in getting back to this thread and this project. Busy since the beginning of summer and haven't had enough time to justify working on this truck.
I did find the time to get the engine running enough to pull it into the shop so it is out of the weather. I have been very happy with how little effort it took for me to get this engine running again. I had a carter YF carburetor which I had rebuilt earlier in the year for another project, so I just swapped the carb, bypassed the fuel tank, and threw on a used upper radiator hose. I bit the bullet and got a new battery for the truck, hooked everything up and turned the key. About five rotations of the crank was enough to get it started. Runs great, a little bit of valve slap from one of the valves, but aside from that it runs and idles very very smoothly. I'm beginning to question whether or not this really might be a 12,000 mile truck rather then a 112,000....
Here are some pictures that show the condition of the original paint after wiping off the oxidation with a warm wet towel. I then buffed the area dry with a soft microfiber cloth. I am very happy with the results. Imagine with some rubbing compound and a good polishing! I am thinking the most delicate approach to washing the dirt, grim and oxidation off the trucks is with a bucket of warm soapy water and a soft truck brush. I am surprised with how vibrate the color is after all these years.
Sodly, this question is particularly for you: I'm beginning to get a bit concerned about the frame on this truck. In a couple of these pictures you can see the "3/4 ton sag" in the space between the front of the bad and the back of the cab.
Being that this really heavy camper has been on this truck since it was new, I don't know how easily the truck could be made to look straight again. I am in the process of locating some camper jacks and will hopefully have the camper off of the truck before winter hits, but what has your experience been in solving this issue? Should I be looking for a new frame?
Sent from my iPhone
murdoc is offline   Reply With Quote
Old 10-07-2015, 10:32 PM   #81
'63GENIII
'63GENIII's Avatar
First off, beautiful truck! What a find with all of the little add ons and cool features in addition to a well made Alaskan. I was getting a little anxiety until I saw your post about saving the LS swap for something else that had been worked over already. I agree, its a nice time capsule!
As far as the frame, from the pics, the gap doesn't look to be closed at the top. It actually looks pretty good to me. As far as having a 2K lb load in it, I used to regularly put nearly 3k worth of concrete, pavers, rock and whatever I needed while working on my house. Some pretty ridiculous loads for a 1/2 ton frame. Anyway, Id be looking at the cab bushings and the little rubber spacers (if the fleet beds have them under the bed) before I started measuring the frame or even thinking about looking for a new one. Does the frame look at all bent or is it just the body lines not lining up right that's got you worried?
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 10-07-2015, 10:35 PM   #82
'63GENIII
'63GENIII's Avatar
Just noticed it's a 3/4 ton. I think the frames are a little bigger than the 1/2 tons. I wouldn't be sweating the frame at all at this point. Start small.
Chris
'63 k15 long step
Old 10-07-2015, 11:05 PM   #83
1971 GMC SHORTY
1971 GMC SHORTY's Avatar
What a Great Truck all Kinds Of Great Stuff I'm Watching This Thread
Best Thing is the Spare Tire Slider
1966 GMC K25 V6 351E Original Utility Truck
2000 C3500 Hot Rod Utility Truck
2003 ROAD KING 100th 124ci 6 Speed
145CI M/P Pro Street FXR
2002 FXDP
2007 2500HD DURAMAX. DD
Studio Teamsters / Mechanic
Retired GM Master Tech 20 Years
Retired Ford Tech 15 Years
1971 GMC SHORTY is offline   Reply With Quote
Old 10-07-2015, 11:31 PM   #84
sodly
sodly's Avatar
Yeah, I'd just echo what 63GENIII said. Unless the frame looks bent, I wouldn't panic until you get that load off the rear to see what you've really got there. Three quarter ton trucks more typically sag at the rear cab mounts. Yours almost looks like the bed is tail heavy or something.
As for reviving the original paint, drop me a PM and I can give you some suggestions for how to do that gently (or did I already talk to you about that... can't remember). Might not be necessary to resort to compound and lose even more paint in the process.
WANTED:
Old 10-07-2015, 11:59 PM   #85
'63GENIII
'63GENIII's Avatar
[QUOTE=sodly;73338 Yours almost looks like the bed is tail heavy or something.
Im glad you saw that as well. I didn't want to get called out for needing glasses! LOL.
Chris
'63 k15 long step
Old 10-08-2015, 01:31 AM   #86
BOE
good find murdoc. it looks real close to my 64. I have the same plan keep it stock and then I will find a shortbed to customize.
BOE is offline   Reply With Quote
Old 10-08-2015, 10:21 PM   #87
sodly
sodly's Avatar
Can't wait to see that pristine bed wood hiding under that camper!
WANTED:
Old 10-10-2015, 11:25 AM   #88
factorystock
factorystock's Avatar
Super clean find, an unaltered truck like this is getting harder and harder to find. I wouldn't hesitate to purchase a truck like that sight unseen. I'm positive there is no frame damage on that 3/4 ton, its just the heavy weight of the camper with the center of gravity mostly behind the rear axle.It appears the paint will buff out nicely, who knows how many trucks were un necessarily completely repainted just because they were heavily oxidized. The hood and roof are obviously beyond reviving, I would just fog in the hood and roof with correct forumula 1966 GM light green, be careful not to use'64-'65 light green, it has a different formula.
factorystock is offline   Reply With Quote
Old 10-13-2015, 12:53 AM   #89
murdoc
murdoc's Avatar
Thanks for the confirmation on keeping it original, I can't believe what plans I initially had in mind for this truck. I was going to scrap the frame and drivetrain, sell the steel rims, the entire bed and camper, (for whatever I could get out of them) and just keep the cab, doors and front clip for an LS short bed conversion project.
I think you are right about the frame, your approach at very least seems the most logical, as well as easiest way to begin looking into the frame. There is nothing I have seen on the frame that would yet lead me to believe it is bent, I guess maybe I'm just a little paranoid.
Old 10-13-2015, 01:01 AM   #90
murdoc
murdoc's Avatar
You and I both!!! I really think I spend too much time thinking about it during the day. I will do my best to not keep you waiting for long!!
Old 10-13-2015, 01:38 AM   #91
murdoc
murdoc's Avatar
This is a very valuable bit of information. I haven't yet considered to add any new paint to this truck, but not knowing there was a difference in the light green color paint in 66 could have been disastrous. There are only a couple of dents on this truck. The worse is on the hood. So fixing the dent and repainting the hood is not entirely out of the question...... what you guys think???
I will be posting more pics tomorrow of all the dents I have found on it so far, both big and small. Hope to not disappoint!!
Old 10-13-2015, 11:27 PM   #92
murdoc
murdoc's Avatar
Here are all the dents. Not sure how much interest anyone has in these pics, but more for reference and perhaps recommendations for ways of pushing these dents out without needing filler or paint. Hell, they really aren't that bad, I'll probably just leave them...
First pic, the front part of the roof. Now I have seen this pattern of indentations along the front roof on several other trucks I've owned in the past. Could have this been a factory imperfection from when they spot welded the roof skin to the rest of the cab?
This one is obvious and pretty normal. Every hood comes with at least one dent right?
I have posted a pic of this one near the beginning of the thread. The only dent on the grill support. The front fenders have absolutely no dents, only the normal rust through at the back bottom section close the rocker panels.
Have posted this dent earlier as well. The hit on the pass. rear bed corner section. More than likely while backing up, it continues on to next image.....
Passenger bedside rear panel. The initial hit moves on a bit further down the bedside, creating a distinct, but not too noticeable crease here...
Only dent on the entire driver's side! Right there on the door before the west coast mirror arm.
Under the passenger bedside, between the rear wheel and the cab. Camper's propane tank pictured, bolted to the frame.
Old 10-14-2015, 01:01 AM   #93
oem4me
That's not too bad, considering it's age. IMO, your choice would be between careful paintless dent repair (youtube PDR) and just letting the dents show. NO WAY under any circumstance should you start beating the dents out from behind. As bad as any legit dent looks, a poorly worked over one is WAAAYY worse.
PDR is a fascinating disipline, and you'd be amazed what a pro can can do with no harm to the factory paint. What might seem kinda expensive for labor, is offset by no cost for paint.
Old 10-14-2015, 01:34 AM   #94
argonaut
argonaut's Avatar
Dents add character. I say polish and drive.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 10-14-2015, 12:33 PM   #95
C/10 King
C/10 King's Avatar
Originally Posted by argonaut View Post
dents add character. I say polish and drive.
x2!
C/10 Rene
1966 Short Fleet "The Hag"
1967 CST Short Fleet "Dark Poly"
1971 Short Fleet
1970 Jimmy Custom 2 WD "Golden Ticket"
1972 Blazer 2 WD "Retro Blaze"
C/10 King is offline   Reply With Quote
Old 10-14-2015, 01:00 PM   #96
TJ's Chevy
TJ's Chevy's Avatar
x3!
Old 10-15-2015, 08:01 PM   #97
jdl71
jdl71's Avatar
x4!
Psalm 23
64 C10
66 K20
jdl71 is offline   Reply With Quote
Old 10-30-2015, 09:49 PM   #98
murdoc
murdoc's Avatar
Took the truck very carefully outside (no functioning brakes) and washed it for the first time in probably 20 years. All of the oxidation came off with just warm water and a soft truck brush. The bucket that held the warm water looked like skim milk once I had finished washing it. Dried it off with micro fiber towel.
Here are the results:
I didn't notice this written on the old belt the first time I went through the glove box......
reads: "This belt came with the truck. Replaced at 11160. July 27-84"
Not sure what to make of that. Pretty much either the truck's odometer had already rolled over by 1984, or the think had only 11,160 miles in 1984. It currently shows 12,094.0 Mysterious.....
Old 10-31-2015, 10:43 AM   #99
1976gmc20
If it was only used for vacations, it's possible that the truck really does only have 12K miles.
Current/past Chevy/GMC trucks:
1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD
Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner
1976gmc20 is offline   Reply With Quote
Old 10-31-2015, 11:42 AM   #100
Greenlee
Greenlee's Avatar
Wow. This is a sweet truck!
Greenlee is offline   Reply With Quote
