Front too low
Is it possible to raise the front end by 1/2" - 1"? Which has mustangII front clip, if so how? Thanks
yoshi's 49 project |
![]() ![]() Join Date: May 2015
Re: Front too low
Donut style coil spring spacer...summit sells em..I don't know about yours but the spacers on my truck are only half as thick as the lift they add... meaning a 1" thick spacer will result in about 2" of lift.
Re: Front too low
What size springs are you using? They generally came in 4 cylinder springs, 6cylinder springs or v8 cylinder springs meaning each spring is rated larger weight capacity equates to larger springs taller springs higher the car
http://67-72chevytrucks.com/vboard/s...d.php?t=436442 |
![]() Join Date: Jul 2007
Re: Front too low
How low is "too low"?
I don't remember what you have for suspension, tires or what not. Lower A arms should be pretty well parallel with the crossmember. Did you order dropped spindles or ? Coil spring or coil over?
Re: Front too low
Better with a picture, 2 1/2" from cross member to floor
Re: Front too low
Thanks, Stronger springs are in order.
A pair of these would help a little and give a quieter ride but I think you need a bit more than that/ http://www.summitracing.com/parts/hd...FYKUfgodk0oAvA Here, same brand but 3/4 of and inch thick. http://www.jegs.com/p/Heidts/Heidts-...95921/10002/-1
Re: Front too low
i agree with mr 48
stronger springs will raise the lower arm to level that's the first true mustII frontend i've seen in a while
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
Re: Front too low
How much would these raise the front end?
Re: Front too low
you can go to autozone and get spring nuggets. Lol, thats what I call them. They twist in between the coils and lift it up.
build thread - 1972 C/10 "Ethyl" 1974 C/10 " Paw Paw" C/10 Club Louisiana ![]() instagram - @esso_c10 @projectpawpaw |
Re: Front too low
change springs
1950 3100 5 window |
Re: Front too low
YES YES, change the springs!
I had a set of Bobcat A/C car springs and they were to harsh so I went to a smaller wire diameter (lighter) spring and the truck rode better and it did put the front end up a bit higher. Look around and check out Pinto, Bobcat, Mustang ll for spring rates, coil diameter and height (quantity of coils). You may have to experiment with a few different kinds until you are happy with the ride and height
![]() Join Date: Jul 2012
Re: Front too low
I agree with the change spring recommendation. This chart may help.
http://www.eatondetroitspring.com/or...-coil-springs/ |
Re: Front too low
I think we can assume that mine is an original m2 front clip so I'm thinking I have the same as these on eBay, Item Number381245375359
#14 | |
Re: Front too low
I do not know what the shipping rate is to the UK !
#15 | |
Re: Front too low
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 Last edited by solidaxel; 05-31-2015 at 03:48 PM. Reason: # 2 Remove! |
