Old 05-29-2015, 08:38 PM   #1
HUSSEY
HUSSEY's Avatar
Friday Night Score
When you're in your late 30's married with kids, this is considered a Friday night score.
Been looking for a decent visor locally for a while and picked this up for $200. Other than the old paint, it's nearly flawless, even all the screws look original. A lady had it left over from an estate sale and she wouldn't budge off the price, but I was ok with it. She threw in some chrome SBC valve covers which won't fit my center bolt heads but hey, they'll either look good hanging on the wall of my garage for the next 50 years or maybe I can get a few bucks out of them.
Only problem is the passenger’s side mounting area. The door shuts tight against the jam and I need a little room for the visor mount and the screws that hold it on. I tried loosening the door hinge but the holes look round so I couldn't get it to pull out. I guess you need to file those holes oval? Guess I'll have to do a little research on how to adjust doors.
My 49 AD Build / S10 Chassis -- Thread -- Pictures -- S10 Conversion Mounts
HUSSEY is offline   Reply With Quote
Old 05-29-2015, 08:53 PM   #2
starterman99
starterman99's Avatar
Re: Friday Night Score
nice score, looks good
1950 5 window
starterman99 is offline   Reply With Quote
Old 05-29-2015, 10:20 PM   #3
midnight rambler
midnight rambler's Avatar
The wife has been dragging me to estates sales the last few weekends havnt scored anything that cool, but i did get some magazines from early birds (1st gen t-bird) 1970 tru 1990 the full years for $25
midnight rambler is offline   Reply With Quote
Old 05-30-2015, 08:43 AM   #4
FarmerSid
FarmerSid's Avatar
Maybe I'm not understanding but the door is hitting the screw heads when you close the door? You should be able to loosen the hinge bolts on the door pillar and pull the door out a bit. My drivers door appears to be in a little too far at the top but the body of the door is flush all way round. I'm going to tweak/bed the upper portion to pull it out to where it needs to be and leave the lower body portion where it's at. Weather stripping may be a cushion in that area. I'm not at that point yet.
I have the same visor and am not going to tweak the door or install the visor till I'm almost ready for paint.
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
Old 05-30-2015, 09:03 AM   #5
HUSSEY
HUSSEY's Avatar
Originally Posted by FarmerSid View Post
Maybe I'm not understanding but the door is hitting the screw heads when you close the door? You should be able to loosen the hinge bolts on the door side and pull the door out a bit. My drivers door appears to be in a little too far at the top but the body of the door is flush all way round. I'm going to tweak/bed the upper portion to pull it out to where it needs to be and leave the lower body portion where it's at. Weather stripping may be a cushion in that area. I'm not at that point yet.
The door would hit the screw heads that mount the visor. Here's a link on door adjustment. I see you do need to file out the hinge holes to move the door in and out (last pic of link).
http://www.stovebolt.com/techtips/doors/alignment.htm
I found this link on the HAMB, social forum A-D TRUCKERS, thread Sticky: Tech, by Cubby. He did a great job putting together a ton of tech links for the AD.
Old 05-30-2015, 09:11 AM   #6
FarmerSid
FarmerSid's Avatar
I've seen that link too. All great info. How does your door fit now? Is it flush and you happy with the gaps? If you pull the door out so that the top doesn't hit the screw heads, the lower part and the rest of the door may be off.
C4 IFS & D44 IRS
5.3 HO L33
Old 05-30-2015, 12:36 PM   #7
HUSSEY
HUSSEY's Avatar
The lower part does need to come in out a bit. The door gap on the drivers side is nice but the passengers side is poor. The slanted door pillar doesn't really have the same contour as the cab, I don't think it was ever right from the factory though I'm in no way building a show truck so it doesn't really matter.
