05-31-2015, 08:19 PM | #426 |
Re: What did you do with your truck today, take 2
mine? its a '65 universal mustang tank from Tanks, inc. nice kit, came with sending unit that works with the stock fuel gauge.
Frank 1957 Chevy 3100 2000 Silverado z71 SOLD 2012 Ram 1500 Quad Cab 1992 International 4700 |
05-31-2015, 08:21 PM | #427 |
finished building the wood bed!
05-31-2015, 09:04 PM | #428 |
Like I used to tell my girls when I posed them with my cars, every old car picture needs a beautiful girl in it. Nice work on the bed and good looking helper.
05-31-2015, 11:23 PM | #429 |
06-02-2015, 12:23 AM | #430 |
Installed the bed floor.
My build http://67-72chevytrucks.com/vboard/s...d.php?t=495795 |
06-05-2015, 12:04 PM | #431 |
Drove it 30 miles to work this morning...
Gonna pick up a new sheet of plywood for a new bed floor at the HW store at lunchtime, and my new 3point seat belts & some other goodies should be waiting for me when I get home tonight, so i'll have a few small projects to goof around with.
_____________________________________ Ben R. 1953 Chevy 3100 Classic Seat Restorations -Preventing me from working on my own projects since 2009! |
06-05-2015, 12:58 PM | #432 |
After 6 months of repairing sheetmetal and replacing panels on cab, finally started working on doors. Got the first door hung back on to fit new inner bottom/outer skin before welding. Got back gaps close. Now working on slicing the front, top area to fit. Still a long ways to go....
Cheers, Jim |
06-05-2015, 02:36 PM | #433 | |
06-05-2015, 02:46 PM | #434 |
I sprayed my bed-liner today.
SEM Pro-Tex tintable. Tinted with the same RAL-6009 Fir Green that the truck is painted with.
I sprayed it all this morning. I was out there before 6AM. There were warning labels packed in the bed-liner box about spraying it in hot, humid conditions which is exactly what we had been having. Pot life is severely reduced and flash times have to be well longer. So, I put the bed-liner cans in cool water last night and started early. It worked out perfect. Normal flash times are 20 minutes but because the humidity was 90%, I gave each coat an hour. Because the whole prepare process took me longer to do than I had figured and I was getting later in the recoat window of the SPI epoxy, I decided to scuff it all with 180 sandpaper just to make sure I wouldn't have any adhesion problems. So, that took me even longer. I've worked on this every day this week and finished the final step of masking yesterday evening. I did that well. I didn't want to take any chances getting the bed-liner on anything I didn't want it on. Here's yesterday's photos: Today's photos after removing the all the masking. The directions have you unmask as soon as the final coat is complete. This SEM Pro-Tex is good stuff. I'm impressed. I had enough for 3 coats of everything. It called for 2 to 3 coats and you have full-coverage by the second coat. It sprays easy and is easy to make it look just like you want with how heavy you put it on and how close you hold the gun. I backed the distance off and went a little lighter on the last coat to give it a little more rough look. If a person wanted it to look more smooth, it would be easy to do but I liked it better a little on the rough side. I think the color came out just great too and my wife (truck is for her) is extremely pleased with the whole look. Make no mistake though. This makes a mess of your shop. Oh well, nice to have a room I built for abuse. Next I will work towards getting the bed painted so I can mount it on the truck and get the room back to work on the paint prep for the fenders, doors and hood. Last edited by roger55; 06-05-2015 at 02:54 PM. |
06-06-2015, 07:20 PM | #435 |
painted my bed with Rustoleum Seaside Gloss.
06-07-2015, 04:13 PM | #436 |
Went out for a run today https://m.youtube.com/watch?v=n5UaTe...ature=youtu.be
yoshi's 49 project |
06-07-2015, 07:36 PM | #437 |
Got the bed cleaned out of parts and the bench seat stripped down.
06-07-2015, 08:02 PM | #438 |
got the flip down license plate bracket done today. i used a stock bracket and a generic flip down bracket. the finished product looks stock with the correct license plate light!
06-10-2015, 04:02 PM | #439 |
I didn't like seeing the rust on the chrome rocker covers
06-10-2015, 04:04 PM | #440 |
So I took 1 off, blasted it & painted it
06-11-2015, 09:07 PM | #441 |
New shoes and the correct hood...
1955 2nd Series Truck |
06-11-2015, 09:35 PM | #442 |
Cut out the rusted floor getting it ready for the replacement panel.
06-12-2015, 12:02 AM | #443 |
06-12-2015, 01:08 PM | #444 |
Yes, the hood does fit nice. Looks good.
06-12-2015, 03:43 PM | #445 |
I found a nice used roll bar for a stepside on craigslist. Now I can make my new diamond-plate bed and put that on top of some frame brackets for the bar and I will be solid.
06-12-2015, 07:54 PM | #446 |
I started this panel below the dash for the A/C vents and switches.
06-12-2015, 09:19 PM | #447 |
changed my toilet paper oil filter,, and drove over to meet my wife for lunch.
raced some guy in a mustang, went head to head, but carb ran out of gas. I need to put in a bigger electric fuel pump. This one is reliable, but cant keep the carb full at wide open throttle past 3rd gear. I have 5 gears, seven if you want to work the overdrive and shift a bunch.
http://http://67-72chevytrucks.com/v...d.php?t=489721 |
06-12-2015, 09:37 PM | #448 |
That panel looks really sharp! Is that aftermarket, and if so from where?
Rick 78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel 71 GMC C25 350/TH400 - Project Angie 59 Chevy SWB Stepside (next in line? Not sure now ) 2001 GMC Sierra K2500 |
06-12-2015, 09:51 PM | #449 |
06-12-2015, 11:42 PM | #450 |
I think the true definition of it is ART WORK ! Nice Job!
