Old 06-02-2015, 11:55 AM   #1
4oldcars
4oldcars's Avatar
wheel lug nut torque
I read that if you over tighten lug nuts you can damage the rotor. Is this true? I've always just used an air gun. Am I over tightening? What is the correct torque for lug nuts (2wd)? I can't find it anywhere except for newer trucks.
4oldcars
Driving:
1971 Jimmy w/68 Chev front clip, 1953 Bel Air 2 dr hdtp, 1996 Roadmaster wagon, 2000 Eldorado
The ones I let go:
1931 2 dr sedan, 1935 pick up, 1938 2 dr sedan, 1962 SS 454, 1963 409 wagon, 1970 short bed, 1972 short bed, 1972 sub, 1976 short bed, 1986 long bed, 03 short bed
4oldcars is offline   Reply With Quote
Old 06-02-2015, 12:29 PM   #2
Bladeboy1998
Re: wheel lug nut torque
I have always used a torque wrench. When I was growing up my dad wouldn't use one, he replaced rotors about every 3 months! He still won't listen to me. I can go years without replacing mine.
Bladeboy1998 is offline   Reply With Quote
Old 06-02-2015, 01:51 PM   #3
truckster
truckster's Avatar
It's a good idea to use a torque wrench. The Autozone vehicle information says my K5 Blazer torque should be 120 pounds, but I don't usually go over 95.
It's also important to torque the lug nuts correctly. I took a vehicle to a tire shop to have all four replaced, and I asked them to make sure they torque the lug nuts correctly. The manager said, "Of course. We use a torque wrench to check them all." Then I watched as a tire tech used an impact to run the lug nuts tight (probably somewhere north of 250 ft-lbs) and then clicked each one with a torque wrench.
truckster is offline   Reply With Quote
Old 06-02-2015, 03:54 PM   #4
Bladeboy1998
I would flip **** on them for that! Lol I was always told 80-95 for most passenger vehicles. On my 2500hd I do 110 and still no problem
Old 06-02-2015, 08:04 PM   #5
JJH Jimmy
JJH Jimmy's Avatar
7/16" lug but should be 80ftlbs. Most tire shops use torque sticks on their impacts and run them down snug and the use a torque wrench for the final torque.
1972 GMC Jimmy 4x4 LS Swap
1985 Chevy K20
1994 GMC Yukon
2021 GMC 2500HD Duramax AT4
My "It's a Jimmy Thing" Build
http://67-72chevytrucks.com/vboard/s...d.php?t=583528
Budget Build 1985 K20
http://67-72chevytrucks.com/vboard/s...d.php?t=801565
JJH Jimmy is offline   Reply With Quote
Old 06-02-2015, 08:08 PM   #6
Chulisohombre
Chulisohombre's Avatar
I just use my old cross lug wrench and torque evenly. Its supposed to be 95 ft lbs by the book.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks.
Chulisohombre is offline   Reply With Quote
Old 06-02-2015, 08:10 PM   #7
jayoldschool
Moderator
One more point: the threads are spec'd to be dry. No lube. No oil, no grease, no anti-seize, etc. Using any lube means you are over torquing by a substantial margin (actual compared to indicated).
jayoldschool is offline   Reply With Quote
Old 06-02-2015, 08:47 PM   #8
GMC-YA68
GMC-YA68's Avatar
Who lubes their lug nuts??
-Keegan-
'72 Jimmy 4x4 - 5.3/4L65E/NP205 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=663780
GMC-YA68 is offline   Reply With Quote
Old 06-03-2015, 01:10 AM   #9
Chulisohombre
18 wheelers use anti seize on the stud to keep it from rusting on and some people try to do the same on regular vehicles.
Old 06-03-2015, 10:00 AM   #10
4oldcars
4oldcars's Avatar
Thanx to all. Lots of good info.
4oldcars
Driving:
The ones I let go:
Old 06-03-2015, 10:16 AM   #11
hemi43
hemi43's Avatar
I use anti-seize on all my lug nuts, and doing so will not over torque them. Lubricant will give a more accurate and consistent bolt stretch, and that's why head bolts/studs must be lubed before torquing. I torque all my 1/2-20 wheel nuts to 95-100 ft lbs. The anti-seize also helps in preventing galling and corrosion because wheel nuts are used in a haesh conditions especially up here in the snow belt.
hemi43 is offline   Reply With Quote
Old 06-03-2015, 10:25 AM   #12
imjeff
imjeff's Avatar
Buy decent rotors. I've never had a rotor warp from incorrect lug nut torque specs. Imagine the poor guy out there somewhere with a flat tire, no torque wrench and no cell service obsessing about whether he should change his tire or die a slow death waiting for a passing motorist with a torque wrench.
I know a guy who's addicted to brake fluid. He says he can stop any time.
72 K10 396
75 Cj5 MPI 350 Chev
67 Chevelle 396, 4 speed
74 FXE
08 Tahoe
imjeff is offline   Reply With Quote
Old 06-03-2015, 10:46 AM   #13
A1971Blazer
A1971Blazer's Avatar
I never do anything more than just run them down to contact with my ½" impact.......then tighten by going in a cross pattern.......never had a warped rotor or any other kind of issue. I do spray with a little penetrating lube or WD40 just to prevent galling the threads.......
A1971Blazer is offline   Reply With Quote
Old 06-03-2015, 11:31 AM   #14
jayoldschool
Moderator
That is all incorrect (except for the end where it makes the lug nuts easier to come off in the rust belt) Using anti-seize is causing you to seriously over torque your nuts. The fastener is specifically specified to be installed DRY. Using anti-seize, and torquing to spec, means that when the torque is indicated 100-ft-lbs, the actual torque is much higher (at least 25%). There is lots of actual quantifiable data out there if you wish to research it.
Old 06-03-2015, 12:27 PM   #15
GCncsuHD
Charlie Daniels w/ a Tq Wrench
GCncsuHD's Avatar
This is correct.
This is absolutely incorrect.
As Jay mentioned, torque specs are always "clean and dry" specs unless otherwise noted. Lug nut torque specs are always dry. Lubing them with oil or anti seize increases the tension on the bolt 20-25% more on average than the dry torque spec. In the same way, rusty, galled threads will reduce the tension. Head bolts are typically noted with lubricated torque specs unlike lug nuts and most other common fasteners.
If you are lubricating your threads, which is not totally a bad idea in harh environments, you should be reducing your applied torque by roughly 20% to get the same tension on the bolt, which is truly what you are trying to attain, torque is just easier to measure.
ΜΟΛΩΝ ΛΑΒΕ
67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works
69 K5 Blazer-Family Beach Cruiser Project
78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s
SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s
GCncsuHD is offline   Reply With Quote
Old 06-03-2015, 01:05 PM   #16
ClassicStyle
ClassicStyle's Avatar
I pretty much run 95-120 depending on the application. My cadillac specs at 155ft lbs and it doesn't have warped rotors...
I've never dealt with warped a rotor from lug nut torque. riding the brakes or a stuck caliper is another story.
ClassicStyle is offline   Reply With Quote
Old 06-03-2015, 02:35 PM   #17
A1971Blazer
Longest thread I've ever seen.........discussing nuts.......
Old 06-03-2015, 10:21 PM   #18
ClassicStyle
It's pretty nutty...
