06-03-2015, 02:44 PM | #1 |
18 Till I Die
1973 with 6 bolt lugs but not 4x4?
Not mine. I thought 72 was the first year for 5 bolt disk brakes? This is a 73 with 6 bolt rallys on it and that would indicate front drum brakes in a 2wd?
http://seattle.craigslist.org/est/cto/5055156404.html
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... |
06-03-2015, 03:25 PM | #2 |
67-72 parts collector,…
Re: 1973 with 6 bolt lugs but not 4x4?
My guess it was a conversion.
Must have had a 6-lug rearend they wanted to use. 6-lug aftermarket rotors and drop spindles. Was this an 8-lug truck before??? I don't know these VIN numbers,...
06-03-2015, 03:38 PM | #3 |
Definitely not a factory thing. i'm guessing he just bought a set of 5 to 6 lug wheel adapters. That would make the most sense.
1982 Sierra Classic K15 RC/LB 6.2L Diesel 700R4 1988 GTA Trans AM 305 TPI 700R4 1993 Formula Firebird LT1 T56 1995 GMC K2500 ECLB 6.5L 4L80E 1996 GMC K3500 CCLB LB7 6L90 |
06-03-2015, 04:47 PM | #4 |
Parts and more parts
In those days, you could order a truck however you wanted it. Many railroad and forestry trucks had heavier duty axles and spring sets on them.
Frank |
06-03-2015, 05:35 PM | #5 |
I saw that truck on eBay last week. I noticed the 6 lug wheels right away. That truck was a 1/2 ton from the factory and should be 5 lug. Someone should email him and ask what's up with the 6 lug wheels.
72 3/4t Custom Deluxe 402/auto 66k Original paint 71 3/4t 4x4 Custom Deluxe 10k original miles Original paint 71 3/4t Cheyenne 402 70k original paint 72 3/4t 4x4 Custom deluxe 72 3/4t 4x4 Custom deluxe 91k original paint 72 Cheyenne/30 Dually 69 Camaro SS396 4-speed 13 GMC 2500HD Duramax I bought new 05 Jeep Wrangler "Willys Edition" 12k miles (I bought new) 85 3/4 ton 4x4 Scottsdale 33k miles original paint 86 1 ton 4x4 SRW Silverado 454 restored 80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint 95 GMC 1 ton dually 4x4 my dad bought new 95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles 2002 2500HD 4x4 regular cab 6.0L 67k miles 2002 2500HD 4x4 regular cab 8.1L 28k miles 2003 GMC 2500HD 4x4 regular cab Diesel 93k miles 67-72 Parts for sale |
06-03-2015, 07:43 PM | #6 | |
I hope this truck was built around a 73-87 4x4 rearend and conversion 2wd 6-lug rotors.
06-04-2015, 09:05 AM | #7 |
In 69-72 the Heavy Half could be ordered as a 6 lug in 2wd. I don't think this carried over into the 73. My guess is someone found a 6 bolt replacment axle and used the 6 bolt rotors in the front - pretty cheap swap. Unlikely it was a 4wd that was converted with a front crossmember swap. Since 73 wil bolt into 72 maybe they had a 72 6 bolt front laying around...
1987 2 ton 1982 250/TH350 beater in progress Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping Plus a mess o' tractors |
06-04-2015, 09:08 AM | #8 | |
Any more info on this would be appreciated.
06-04-2015, 09:51 AM | #9 |
Here is the VIN:
T- GMC C-Conventional Cab Z- 454 Engine 1-1/2 Ton 4- Cab and Box 3-Model year 73 Z-Built in Fremont 503807 - Sequence Number
Trevor 74 C20...work in progress. 04 Saturn Ion...Daily Driver |
06-04-2015, 10:08 AM | #10 |
You could get the 454 in a C10? I thought a C20 or bigger was required to order a 454.
Tony Nicholas @ Midwest Metal Masters 1953 Chevy 3100 392 Hemi w/727 & 9” Ford 1985 Chevy C/10 6.0L 4L80 373 locker |
06-04-2015, 01:41 PM | #11 |
You could order them in the higher end models like the Cheyenne Super/Sierra Grande and the BIG 10 trucks as well. K10 trucks couldn't get a BBC as far as I know. Some of the special edition sport trucks could be optioned with it also.
06-04-2015, 02:23 PM | #12 |
Yup, and for 1976, the C10 with 454 was the fastest accelerator on the road. Beats the corvette. There was a road & track or car and driver article testing it at the time. Everything non-truck was wiped out by smog controls.
Greg 64 GMC Suburban - 283, NV3500, 14 bolt 77 C10 swb - 292, SM465, 12 bolt |
06-09-2015, 06:31 AM | #13 |
I asked the owner about the 6 lug wheels and this was his response,
You are correct. When the lower kit was installed the current rally wheels were found and wanted to be used then because of looks and better width. When the front end was replaced/rebuilt including brakes the front rotors were swapped with new 6 lug and the axle shafts were replaced with new wheel bearings. There are no adaptors on the truck.
06-09-2015, 07:29 AM | #14 | |
Seems like a lot of expense to fit a set of 6-lug rally wheels that are the same width as a set of 5-lug rally wheels. But that's what makes everyone different.
06-09-2015, 07:35 AM | #15 |
That was my thought to Keith, they must have really wanted the 6 lug. And with a claimed 32k miles the front end shouldn't have needed a complete rebuild? Whatever the story is with it, it's a nice truck
06-10-2015, 10:24 AM | #16 | |
454 was available in a C10 through '79 or '80. Not available in a K10 or even K20 though. Or even the early K30's actually.
-Andy '77 K5 Blazer '78 K10 Shortbed '78 C20 Suburban '79 K30 Crew Cab Dually '84 C10 Short Stepside '88 K20 Suburban |
06-10-2015, 09:42 PM | #17 |
I figured exactly what the seller said. Not necessarily that much extra expense and I think it gives super cool factor, as a truck. What a sharp truck, too!
There was never a heavy half 6-lug 2wd offered. Back in the day when you could these trucks any way you wanted, you couldn't order that. It had to be something used on some other production model. They didn't custom make parts for anyone.
