Old 06-03-2015, 06:29 PM   #1
ufbugman
1970 c 10
Found a c-10 to 1970 swb fleetside for $1500 no engine or transmission body pretty good but will need rockers. my question is it's 6 lug, I'd be lowering it and putting drop spindle on the fron so that's no problem converting to 5 lug..
But what do i need to do on the rear end , just change axles or whole rearend? and what axles?
Dennis
ufbugman is offline   Reply With Quote
Old 06-03-2015, 07:33 PM   #2
Kennuck
Kennuck's Avatar
Re: 1970 c 10
Just swap out the axles from a five lug truck. The axles were the same through the seventies so there are lots out there. Just make sure you have the wider axle some say 1970 was a changeover year and some had the earlier shorter axles. Mine had the wider axle.
1970 Short Wide
5.3 4L60E BlackBear tune
3:73 gears, Boyd's Tank
2.5 / 4 drop 5 lug disc brakes
Vintage Air
18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear
Kennuck is offline   Reply With Quote
Old 06-04-2015, 09:45 AM   #3
Steve Cole
Re: 1970 c 10
You can pull your axles and have them redrilled to the 5 lug pattern or buy new ones from Moser Engineering or similar. Check Summit Racing, they sell them. You also need the 5 lug brake drums too. Many places sell this as a "kit." Check Early Classics, or CPP for the kits.
Steve Cole is offline   Reply With Quote
