Old 06-04-2015, 04:47 AM   #1
GRSEMONKY
73-87 exhaust manifold
Has anyone modified their frame to use the truck manifold's that come on the 5.3 . I was looking at the swap TRUCKS did on the 72 and they bent and notched the frame on the passenger side to use the stock truck headers just want to know if this can be done on the 76. Trying to keep cost down since I have the complete exhaust off a suburban to use in my swap.
GRSEMONKY is offline   Reply With Quote
Old 06-04-2015, 09:50 AM   #2
dayj1
Re: 73-87 exhaust manifold
I notched the frame on an '86 for passenger side manifold clearance. It doesn't take much. Maybe 1/2".
dayj1 is offline   Reply With Quote
Old 06-04-2015, 11:21 AM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
It'll also depend a bit if the manifold were the EGR ones or not. The EGR manifolds have an extra hump on the outer primary of one manifold. They all will fit flipped backwards with a turbo.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-04-2015, 12:19 PM   #4
GRSEMONKY
My manifolds do have the egr port. Turbo would be nice but this is a budget build...at least for now
Old 06-04-2015, 01:50 PM   #5
dayj1
On my '86, the area that needed to be clearanced was for the flange of the exhaust manifold (where it bolts to the down pipe). EGR clearance wasn't an issue for me, but it probably depends on the type of mount and the exact position of the engine.
Old 06-04-2015, 08:31 PM   #6
GRSEMONKY
I'm using LSX INOVATIOS adapter plates. The ones that have the 3 different positions.
Old 06-05-2015, 02:12 AM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Thats doesn't really tell us much. There are like 50 companies doing versions of adapter plates, perches, and mounts, all of which are very very similar.
The EGR is in the way of the edge of the frame rail, at least in the earlier trucks...IF your engine is sitting more towards the front set of perch holes (again, exact position will be relative). If your far enough back, the frame widens slightly and the EGR can clear. The trimming is minimal if needed.
As was also mentioned the flange can be in the way, but this again depends on how far back the engine sits. If you were to run Vbands instead of the 3 bolt flanges, the is no clearance problem. In some cases, you don't have to trim...but it requires using a REALLY odd combo of wrenches and getting a gasket in place is nearly impossible since its in between the lips of the frame rail.
From my experience, if your running a 4l80e, the very outer corner of the bellhousing ear on one side or the other may interfere slightly with the exhaust hardware. This was the case with my TBSS's. It only requires a minor shaving of the cast aluminum ear, which doesn't hurt anything.
Old 06-09-2015, 05:58 PM   #8
Houston Ben
Houston Ben's Avatar
I used DD mounts and had to bend the frame like on trucks on the passenger side. Works fine.
Houston Ben is offline   Reply With Quote
