Old 06-07-2015, 12:34 PM   #1
1964GMC
Advice/Thoughts on serpentine/front drive systems
Looking to put a serpentine drive system on my 283. I have no bolts in the heads, so looking at aftermarket systems. This will be a daily driver so I'm looking for the most reliable and trouble free unit. I like the Vintage Air front runner set up, mainly because of the idler pulley. Plus it just looks more rigid/sturdy. I'm also planning on running the Vintage Air A/C system as well.
Anybody have any thoughts or experiences?
1964GMC is offline   Reply With Quote
Old 06-07-2015, 03:38 PM   #2
Chevy Fleetside
Chevy Fleetside's Avatar
Re: Advice/Thoughts on serpentine/front drive systems
Link?
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 06-08-2015, 10:39 PM   #3
RLag
This is a bit pricey but here is my new March Protrack II on a bbc - does not attach to the heads.
RLag is offline   Reply With Quote
Old 06-09-2015, 12:21 AM   #4
par4tom
I just did the same thing you are wanting to do on my sbc. I used the March Brackets kit but on my kit, the bottom alternator bolt is tied into the head. However, they do offer another kit that hangs off the water pump which would work on yours. I have the 6 rib belt with power steering.
Sorry about the pic angle...
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=705185
How to Get Audiophile Sound in 60-66 Trucks
http://67-72chevytrucks.com/vboard/s...=1#post7236896
Building Your Own Speaker Kick Pods
http://http://67-72chevytrucks.com/vboard/showthread.php?t=730495
par4tom is offline   Reply With Quote
Old 06-09-2015, 01:00 AM   #5
doobiebro
doobiebro's Avatar
Not sure how a serpentine belt assy will mount without the threaded holes on the heads? Haven't seen any kits but I'm sure they are out there...
This is what I did - post 4. http://67-72chevytrucks.com/vboard/s...d.php?t=580055
CURRENT & PAST CHEVY TRUCKS
60 C-10 Apache short step side
62 C-10 short step side
66 GMC Long bed fleet side 305 V-6
77 C-20 Custom Deluxe (Blue Goose)
doobiebro is offline   Reply With Quote
Old 06-09-2015, 06:20 AM   #6
The Rocknrod
Moderator
The Rocknrod's Avatar
I like those late serpentine brackets, I'm thinking of going that way myself.
Old 06-09-2015, 02:09 PM   #7
par4tom
Nice work there on that motor...nice and simple!!!
My Build Thread
Old 06-10-2015, 09:01 AM   #8
Dubnova
I have used the Vintage Air Front Runner on several engines and they are really good. Very pricey but, you might be able to call Vintage Air and talk them out of some sort of package deal. Worth a try.
Dubnova is offline   Reply With Quote
Old 06-10-2015, 03:50 PM   #9
Jimal
Jimal's Avatar
I'm definitely going the serpentine belt route. I found a link to a Hot Rod magazine article that describes how to do this swap on the cheap, using a combination of wrecking yard and Rock Auto Parts for less than $300 (in 2009 at least).
http://www.hotrod.com/how-to/engine/...ne-belt-drive/
Jimal is offline   Reply With Quote
Old 06-10-2015, 04:57 PM   #10
Joe Pass
Joe Pass's Avatar
Very nice.....
Joe Pass is offline   Reply With Quote
Old 06-11-2015, 10:03 AM   #11
1964GMC
Thanks for the input. I wish that I had drilled heads, then the stock late model set up would work nicely. Not building a show truck, just a good daily driver and toad for the motorhome.
I'm forced to use a system that hangs from the water pump. March, Billet Specialities, Vintage Air, are the main ones that I've looked at. Just not a big fan of the way March's bracket's look. I'm looking for understated and function, not HELLO, LOOK AT ME! hahaha
Leaning real hard toward the Vintage Air setup. I like the understated look of it, and I like the use of a real spring loaded idler pulley. Probably going with their Black system. Anything polished or chrome, the salt air here on the Gulf Coast attacks it. My T-Bucket is rusting away,,,,
Old 06-11-2015, 02:53 PM   #12
doobiebro
doobiebro's Avatar
Like to see some pics?..
Old 06-11-2015, 10:44 PM   #13
BigDan3131
BigDan3131's Avatar
I would contact Kwik Performance they can build it anyway to work with what you have. When my former boss called them they were very friendly and knew exactly what we needed and shipped it fast.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 07-06-2015, 03:40 PM   #14
Jimal
Jimal's Avatar
I have my brackets and I ordered up the new accessories last week. I think my biggest concern at the moment is the mount sticking off the front of the manifold, and whether I'll need to trim it in order to get the driver's side bracket on.
Old 08-04-2015, 09:43 AM   #15
Jimal
Jimal's Avatar
Completed my serpentine conversion over the weekend. Ended up not needing to do anything with the generator/AC mount off the exhaust manifold.
