Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 06-11-2015, 07:58 PM   #1
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Ford 9"
I have a friend that has a Ford 9". He says something about 'the one with the big bearing' - I'm not sure what that means.
Anyway, he wants $350.
I'm not sure if it's a good deal or not.
I'm kinda interested myself, but I really don't need it.
I figured I'd post it here just in case someone was interested.
Also, feel free to post what you know about Ford 9" rearends and/or if he is way off on his asking price.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 06-11-2015, 08:27 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Ford 9"
Does it have any brackets welded on to it?
Does it have a third member and axles installed?
Large and small bearings has to do with the hole in the end of the axle housing. Early axles used the large caged ball bearing setup. Later they went to a tapered roller bearing which is smaller in diameter.
The only connection between spline count is early axles tended to be 28 spline. The 31's came along later to handle higher hp.
Old 06-11-2015, 08:32 PM   #3
LostMy65
LostMy65's Avatar
Re: Ford 9"
At this time, I don't know a lot about it.
I'm guessing it's complete.
I can ask him more about it tomorrow.
Old 06-11-2015, 08:59 PM   #4
DakotaKid
Re: Ford 9"
They also had Big Bearing Carriers.
Current Project : 1962 Chevy SWB Fleetside
Others, 1958 Edsel Villager Station Wagon
1926 Ford Model T Roadster Hotrod
www.suedescarclub.com
DakotaKid is offline   Reply With Quote
Old 06-11-2015, 09:01 PM   #5
LostMy65
LostMy65's Avatar
Re: Ford 9"
Maybe that's what he meant when he said it had the big bearing.
Old 06-11-2015, 10:57 PM   #6
Captainfab
60-66 Nut
Re: Ford 9"
The width of the rear end will be a huge factor in whether someone can use it in their application.
Old 06-18-2015, 10:19 PM   #7
LostMy65
LostMy65's Avatar
Re: Ford 9"
He still hasn't measured it for me.
I told him to measure from wheel mounting surface to wheel mounting surface.
