Old 06-13-2015, 10:41 PM   #1
ho70
ho70's Avatar
fuel line woes
Ok, 1979 model Rochester Qjet on truck (72 402, auto) when bought it. Carb inline filter kpt clogging after two hours driving. Replaced gas tank with new tank and sender and rubber lines from sender to OEM line. Still clogging, so replaced fuel pump-still clogging. Found inline filter under cab and replaced now truck will not run over 40 mph as it starves for fuel. Probably gonna replace lines and take carb apart to clean. Do I have to replace return line as well?
ho70 is offline   Reply With Quote
Old 06-13-2015, 10:58 PM   #2
D-rock1981
D-rock1981's Avatar
Re: fuel line woes
Make sure you put the filter on with the flow going the right direction. Return line on a carberator?
D-rock1981 is offline   Reply With Quote
Old 06-13-2015, 11:50 PM   #3
ho70
ho70's Avatar
Re: fuel line woes
no gonna replace the tank to fuel pump line and wondering if I have to replace the return line to tank as well
Old 06-14-2015, 12:27 AM   #4
geezer#99
geezer#99's Avatar
Re: fuel line woes
Might as well!
You're making new lines anyway.
geezer#99 is online now   Reply With Quote
Old 06-14-2015, 12:31 AM   #5
In The Ten Ring
Re: fuel line woes
By "return lines" do you mean your vent to charcoal canister lines?
I just finished making my own fuel lines to get rid of all the rust my fuel system was clogged with. I ran Krud Kutter (Lowe's) through my old vent lines to clean those. I hope I don't have to make a new vent line!
(New fuel pump, rebuilt carb, renewed fuel tank).
In The Ten Ring is offline   Reply With Quote
Old 06-14-2015, 04:26 AM   #6
cdowns
cdowns's Avatar
Re: fuel line woes
have you tried the gascap for built up pressure if yes you have a bad or no vent
