Old 06-17-2015, 09:40 PM   #1
MURPH82
Porterbuilt install help
I am currently mocking up my engine and transmission. It's a SBC with a 700R4. I am running into 2 problems, first my oil pan hits the rack and second how high should the transmission crossmember be in the frame. With my transmission at 5 degrees the mount is almost at the top of the frame. I almost forgot it's a 84 with the extreme front.
MURPH82 is offline   Reply With Quote
Old 06-19-2015, 08:00 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Porterbuilt install help
The trans is pointing DOWN 5 degrees and the frame rails are level with the ground front to back and side to side?
Keith
Convert to disc brakes.
Old 06-19-2015, 08:36 PM   #3
MURPH82
Yes with the frame laying on the ground I can't get the trans to 5 deg without the engine hitting the rack.
Old 06-19-2015, 08:40 PM   #4
lolife99
lolife99's Avatar
Seems like if you lowered the back of the trans the front of the oil pan would pivot up.
Can you post pics?
Keith
Old 06-19-2015, 08:52 PM   #5
MURPH82
I'm actually raising it to get to 5 deg
Old 06-19-2015, 10:41 PM   #6
Rochlow
Steeds sells offset bushing to drop you rack down 1/4". You will have to have them machined down to be the same diameter as the bushing holes on the rack. But, it worked for me.
///Relaxed Atmosphere
Rochlow is offline   Reply With Quote
Old 06-19-2015, 11:01 PM   #7
MURPH82
Old 06-19-2015, 11:02 PM   #8
MURPH82
So you had the same problem ?
Old 06-19-2015, 11:12 PM   #9
lolife99
lolife99's Avatar
I wish you could post a pic.
Your trans tailshaft should be at -5 degrees (5 degrees down) and the rearend should be at +5 degrees (5 degrees up).
I can't imagine the trans crossmember needs to be at the top of the frame rails.
Keith
Old 06-19-2015, 11:14 PM   #10
MURPH82
Not sure how to post pictures but I am measuring the angle off the tailshaft.
Old 06-21-2015, 11:24 AM   #11
DLW
You can email me the pics and I can post them for you if you want danwade66@gmail.com.
Also, your trans tail shaft is pointing down to the ground 5*? You running the level 3?
Send me the pics and include some of your motor mounts, oil pan and trans and I will post them up for you.
DLW is offline   Reply With Quote
Old 06-21-2015, 12:38 PM   #12
MURPH82
I just sent you over some photos. Yes I am running the level 3 and if I go above 6-7 degrees the oil pan contacts the rack.
Old 06-21-2015, 12:39 PM   #13
MURPH82
Old 06-21-2015, 12:45 PM   #14
DLW
Here is the photo's MURPH sent. The trans crossmember seems fine in this photo but I assume it needs to go up a bit further? Can't really rell whats happening with your R&P and oil pan though.
Old 06-21-2015, 12:48 PM   #15
MURPH82
I'll resend you the pictures where the oil pan is contacting the rack
Old 06-21-2015, 02:21 PM   #16
DLW
The rest of your pics ..hopefully someone can chime in here with some more help, maybe even Nate. I have the mild and an LS3 so not seeing your issue. It would seem your engine either needs to be raised or a different oil pan.
Old 06-21-2015, 07:08 PM   #17
MURPH82
I feel that either pan or rack is the problem. I went up to the shop today and I can get the carb mounting surface to 3.5deg and I have just a lil daylight between the rack and oil pan. I wonder if the uninterrupted rack is a little thinner than the rack I have. The motor is a 383 so I don't know if there is a smaller oil pan I can use and it still clear the rack.
Old 06-21-2015, 10:04 PM   #18
Rochlow
The most I could get my transmission angle down was 8-9 degrees without the oil pan hitting the rack. Nate made engine mounts to raise the engine position 1/4" and 1/2".. 1/2" made the trans yolk hit the cab floor, so I used the 1/4". I also bought steeda bushings to drop the rack another 1/4". I dropped the trans crossmember to the bottom of the frame and used a spacer to to make up the difference. Still the best I could do was 6 degrees down.
I'm still working on the drive line issues with Nate
Old 06-21-2015, 10:59 PM   #19
MURPH82
What brand rack and pinion are you using. If I cleared the rack I think I would be ok. It's just frustrating because I am in a crunch to get done. I also wonder if there are any other oil pan options ?
Old 06-22-2015, 06:39 AM   #20
lolife99
lolife99's Avatar
There are 2 different oem oil pans.
You might contact one of the aftermarket oil pan manufacturers and see if they can help.
Keith
Old 06-22-2015, 07:43 AM   #21
Rochlow
I'm using the rack supplied by Nate
Old 06-22-2015, 12:50 PM   #22
DLW
Should be the unisteer R&P then, that's what I got.
Give Nate a call, he is really good about responding and helping. He would even send you some custom mounts if necessary. I dealt with him a lot and he was great at helping or resolving any issues I had.
Old 06-22-2015, 12:53 PM   #23
MURPH82
I am considering just leaving the pinion at 7 deg and running a double cardan joint drive shaft or putting a washer on the rack to move it forward just a hair.
Old 06-22-2015, 01:09 PM   #24
DLW
Could try something like was mentioned above like these http://www.summitracing.com/parts/sd...4011/overview/
I would still check with Nate, moving things messes with geometry.
Old 06-22-2015, 03:38 PM   #25
Rochlow
I spoke with Nate about the above process. He believed that the amount that the rack was going to be moved would not create any noticible geometry issues.
