Old 06-17-2015, 11:19 PM   #1
guitardude127
8 Lug Disc Conversion?
I have a 1969 GMC 3/4 ton long bed, step side that I'm working on redoing. The project has been stalled for about a year due to lack of funds and lack of time. Both of those have changed and I'm ready to start up where I left off. So...
The truck has 8 lug drums all around. I'm wanting to upgrade the fronts to disc. Any advice for pulling this off? I can find 6 lug kits everywhere, but what can I do for 8 lug?
Thanks!
guitardude127 is offline   Reply With Quote
Old 06-17-2015, 11:54 PM   #2
SS Tim
SS Tim's Avatar
Re: 8 Lug Disc Conversion?
Factory parts, this link and the search button have you covered.
http://67-72chevytrucks.com/vboard/s...68&postcount=4
SS Tim is offline   Reply With Quote
Old 06-17-2015, 11:56 PM   #3
Saclandman
Saclandman's Avatar
Pull the front suspension, crossmember and everything, from a 71 and up c20. Square bodies are plentiful. Grab the master cylinder, booster, and proportioning valve too. As far as a kit, I'm sure there is someone out there who makes them. I just haven't found any for a reasonable price.
Rich J.
1967 Chevy C20 Longbed Stepside w/283 and 4spdSOLD
2002 Chevy Tahoe 4X4 5.3L SOLD
2015 Chevy Silverado Crew 4X4 5.3L
Saclandman is offline   Reply With Quote
Old 06-18-2015, 07:40 AM   #4
MARKDTN
Agree. Factory stuff and get-'er-done.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 06-18-2015, 11:43 AM   #5
70's luvr
out of a 1980.
70's luvr is offline   Reply With Quote
Old 06-18-2015, 01:12 PM   #6
cooperhw
cooperhw's Avatar
^^^I agree^^^
I am doing a 68 1ton dually so I found a rolling 1979 dually chassis for $250. In one day I pulled out my entire front crossmember, the one under the donor, and installed the 79 unit under my dually. U only have to elongate one hole per side and drill one hole per side. My 1 ton also required a couple more holes (not required on 3/4 ton) per side thru the top frame rail to put an inserted c channel brace that came from the factory on the tonners.
It's really easy.
Oh yeah, did mine by myself in one day. I am sure it would go much easier with some help.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 06-18-2015, 02:36 PM   #7
RichardJ
>>per side thru the top frame rail to put an inserted c channel brace that came from the factory on the tonners.<<
The picture of an '80 cross member that 70's luvr has above shows pressed steel brackets that the upper A-arms bolt to. That truck probably had the c channel brace, inside the frame rail. My '67 and I'm not sure what other years had forged steel brackets and no c channel brace.
The later style has the brake lines and the Combination Valve mounted on the small cross member, under the radiator. There is a brake line connector under the passenger side floor board. Take all the brake lines from the connector forward and everything including the flex brake lines will bolt in place.
Try using your old brake lines and you will be on here with a new post trying to figure out what new flex lines you need to jury rig your mix matched parts.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
