06-18-2015, 03:40 PM | #1 |
tranny help needed
hi guys I just recently replaced my tranny pan on my th400 with 350 engine. I got a b&m pan cast aluminum then I replaced my transmission cooler lines and modulator. Now I got no leaks but my truck won't shift out of first gear and its at high rpm. What happened? any ideas? really frustrated cuz it worked fine before I did that. thanks.
06-18-2015, 03:56 PM | #2 |
Re: tranny help needed
its the modulator , maybe you kinked the line
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
06-18-2015, 04:51 PM | #3 |
Now that's not a nice thing to call Bruce Jenner
"Life is too short to drive a boring vehicle". Later, Wayne |
06-18-2015, 04:52 PM | #4 |
06-18-2015, 04:56 PM | #5 |
Lol checked the line its not kinked but bruce jenner couldn't help either
Posted via Mobile Device |
06-18-2015, 06:11 PM | #6 |
have u checked it twice or three times to see if it is full of fluid?
06-18-2015, 06:20 PM | #7 | |
You mentioned you added the aftermarket aluminum pan which may have added a couple of quarts to your capacity.
1971 Cheyenne Big Block Longhorn |
06-18-2015, 06:57 PM | #8 |
yup i bet the new pan added capacity to the fluid
1967custom |
06-18-2015, 07:22 PM | #9 |
Don't flame me for this but what about the o-ring around the filter. Now this is where the flame part comes in I don't remember the 400 trans and how the filter goes on. Whether it is a bolt on or push in filter like the 700r4. The o-ring could be cut [or left off] and that will cause just what your describing. I also remember one of those bolting on with a gasket under the filter and that will cause the same problem. Also the deep pans normally come with a adapter to drop the filter down into the pan So to make up the difference in the deep pan as opposed to the regular one. But the deep pan takes about 2[two] more quarts than the regular the thinking is more fluid will cool more area.[also the aluminum helps in that]But I'm sure you already knew that, sorry for my rambling
06-18-2015, 09:16 PM | #10 |
well I believe it has fluid everywhere. she sat for 2 weeks could fluid have come out of torque converter and if so can it be filled easily? also I replaced the trans cooler hoses can their be any airlock that could do this?
06-18-2015, 09:25 PM | #11 |
this thread
The torque converter fills as the engine runs - so fluid in the transmission fills the torque converter and you'd notice the fluid level decrease when checking the level. I'd say not enough fluid would be noticeable more in shifting into gear. Getting stuck in gear - modulator.
project: "my happy mess" |
06-18-2015, 10:13 PM | #12 |
well guys thank you so much I'd buy u all a beer if I could. turns out it was all low fluid she runs like a dream now. Thanks. A ****ty day turned good.
