Old 06-20-2015, 02:27 PM   #1
Pat leary
How to tell what motor is in a 1972 CMC
I just bought a 1972 GMC 2500 from northern California; it was part of an estate sale. It was an old ranch truck with 31,000 original miles that the son had been using for the last ten years or so, AC, power steering and power front disc brakes. The truck has not yet been shipped home to Massachusetts but the question I have is how do you tell what engine is in it. I know it is a big block the seller said last time he had it serviced that the mechanic looked up the numbers and told him it was a 454. My gut feeling is it is a 402, I looked up the VIN on the web and just identified as an eight cylinder. The truck looks like it has never had anything done to it, original paint etc. and with only 31,00 I would think it is matching numbers. If anyone could give me some guidance I would appreciate it.
Thanks, Pat
Pat leary is offline   Reply With Quote
Old 06-20-2015, 02:41 PM   #2
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Re: How to tell what motor is in a 1972 CMC
Hi Pat and welcome to the site. It makes sense that the BB in the truck should be a 402. Its possible the 402 blew up and a 454 was installed as replacement. By the way, you must have pictures of your truck and we love pictures on this site.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 06-20-2015, 05:31 PM   #3
davepl
davepl's Avatar
Need the three casting code off the block as a start. For example mine is
TO42TTBG
..which decodes to 1970 truck w/ TH400, L-47 310hp 402
So you can narrow it down to "is this a motor that could have come with it?" but never to matching numbers as trucks didn't get serialized engines.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 06-21-2015, 12:39 PM   #4
Pat leary
Thanks for the information, it looks like I will have to wait for the truck get home and look at the numbers cast into the block. Are the numbers somewhere that can be accessed with the motor still in the truck?
I only have one picture of the truck, I will try and post the one that I have.
Thanks again, Pat
Old 06-21-2015, 12:46 PM   #5
geezer#99
geezer#99's Avatar
Look here for where to look.
http://www.mortec.com/
Old 06-21-2015, 01:05 PM   #6
Pat leary
Thanks,
I will check them out.
Old 06-21-2015, 02:37 PM   #7
67 chevelle
67 chevelle's Avatar
if the number is on the block in front of the passenger head thats an easy one to get to and read ,, otherwise taking a valve cover off and checking the number cast in the middle of the head is also a good indication ,, as long as you have decent heads any big block will run well ,, peanut port heads run alright but lose it at higher rpm
here is a direct link to moretecs sight
http://www.mortec.com/location.htm
on moretecs sight you are hoping to see number 4 , blocks that have been surfaced lose the nomenclature
then onto numer 1 , they will be there
an example would be 3999241 ,, that is an 402 truck head number
nasty z28s site is better imo for casting numbers
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 09-03-2015, 10:05 PM   #8
Pat leary
I finally got the truck home, it took almost two month. It has a 402 in it, there is a foil tag on the valve cover with build date and displacement. There is also a sticker on the radiator support with the emission information that is marked 402.
I went to buy new tiers and was told the 16.5” tiers are getting hard to find. Is there a later year truck with ether 16” or 17” rims that will have the same 8 lug bolt pattern, center hole and offset so I can look for a used set.
Thanks, Pat
Old 09-03-2015, 10:39 PM   #9
68350
68350's Avatar
Look for a set of rims off of a 73 and up. They are 16" rims and should be easy to find. Tires are easy too
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets
68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction
69 Chevy Camaro SS, 383, 4 speed, positraction
70 Chevy El Camino SS396, Triple Black, 454/th400, Tach
70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks
70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR
71 Chevy Blazer, CST, 350/auto
71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s
71 Custom/30, Open Road, 350/th400, tilt
72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi
72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi
68350 is offline   Reply With Quote
Old 09-04-2015, 05:18 AM   #10
Pat leary
Thanks,
That was what I was hoping.
Pat
