Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1947 - 1959 Chevrolet & GMC Pickups Part Board
Old 06-23-2015, 01:05 AM   #1
Coupeguy2001
Coupeguy2001's Avatar
chevy parts
More stuff, not year specific.
for small block chevy:
62 chevy power steering pump
crank pulleys
water pump pulleys
flywheels
flex plates
clutches
clutch cores
327 engine with iron, bolt hole, fuelie heads(so you can bolt on air conditioning), 041 castings, hardened seats 202-160.
screw in studs, machined for perfect circle seals
86 corvette 350 long block one piece seal 58,000 miles, corvette low clearance pan, 86 iron heads. New Summit cam, timing gears one piece pan gasket new head gaskets
71 chevy 350 4 bolt main, 2 piece seal, 3000 miles, 92 firebird heads , Edelbrock intake, 2 piece timing cover, aluminum Edelbrock water pump, mild cam, runs good
56 chevy 265 long block, power pack heads, no pan or intake .060 over, needs to be re-ringed only because it has been sitting. no ridge in cylinders.
hillenger512@cox.net
602-510-2519
Coupeguy2001 is offline   Reply With Quote
chevy small block 350
