04-29-2015, 10:40 AM | #101 | |
Re: 1955 (2nd gen) first timer..
Thanks man! I'll do some measuring for you when I get home I forgot lol Im also gonna pm you back about the coilovers today |
05-02-2015, 01:31 AM | #102 | |
Cameron, your rear suspension looking real good ! Rear half shafts need to be parallel to the ground for the best ride quality, say you have six inches of total rear travel 3in up & 3in down with the half shaft u-joints. Close up pic Bro Mario 56 GMC rear half shaft parallel to the ground at ride height. Harvey 1957 Chevy Stepside 1958 GMC Fleetside C4 build thread: http://67-72chevytrucks.com/vboard/s...=535686&page=6 |
05-02-2015, 10:42 PM | #103 | |
Thanks harvey!! |
05-02-2015, 10:46 PM | #104 |
Got some brackets made for the corvette rear end.. almost had it done ran out of wire on the mig
cleaned up the rear end a little bit. that aluminum sure does turn out nice! |
05-02-2015, 11:36 PM | #105 |
Seem like when you need the welder the most, it runs out of wire or gas on the weekend...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
05-02-2015, 11:48 PM | #106 |
Looks good Samples. Seems wire or gas does like to run out on the week end.
05-03-2015, 08:31 AM | #107 | |
Thanks AD! And it sure does.. I knew it was goin to because it started poping a little bit, the spool is so big the wire gets a little rusty towards the end lol |
05-03-2015, 01:14 PM | #108 |
Looking real nice.
Kim |
05-03-2015, 06:00 PM | #109 |
Samples, did you figure out if bag brackets will work?
05-03-2015, 11:20 PM | #110 |
05-03-2015, 11:22 PM | #111 |
AD, I'm not gonna use air ride.. I looked into some air over shock kits and they were a little much for me! I'm just gonna use coilovers front and rear!
05-25-2015, 08:48 PM | #112 |
Well im trying to set up the driveline.. im gonna have to notch that crossmember.. can someone tell me what angle my rearend is suppose to be? my trans? what angle should the driveline be? i have no ideal where to go from here.. thats just a mock up driveline by the way
05-25-2015, 09:31 PM | #113 |
A320 Pilot/USAF Retired
Carb flange should be set level, this usually results in the trans being about 3* down.
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
05-25-2015, 09:38 PM | #114 | |
If I set carb flange level I'm pretty sure I'd have to run a tunnel through the whole cab.. |
05-26-2015, 11:00 AM | #115 |
Can you get the engine lower? Get your engine set where it needs to be. Then match the pinion angle the same as the crankshaft.
05-26-2015, 12:47 PM | #116 |
Hmmm, such a simple and obvious rule of thumb that I'd never thought of before. I knew the driveshaft angle was usually 3 degrees downward to the rear but ever knew where that came from. Live and learn!
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
06-23-2015, 06:22 PM | #117 |
any progress?
06-24-2015, 10:05 AM | #118 |
Well, I'm in the same boat now. Trying to figure out whether to tilt the rear end carrier or not. My engine ended up higher than the rear end. Your step notch is higher than mine. If I lower the engine more, the transmission pan will drag when aired out. If I raise the engine to be able to air it out, I will have to modify the floor pan, and tilt the rear end carrier even more to get the u-joints in spec. Keep us posted!
06-24-2015, 03:43 PM | #119 |
Watch this video... it explains everything you need to know about angle of the dangle.
https://www.youtube.com/watch?v=KZ-m9ov3wYM Understand why 'angle is required'.... for the driveline u-joint cap needle bearings to operate properly they need only a minium of a 1* angle to keep them rotating. If there is no angle the needle bearings inside the caps do not turn and they will deform quicker. When you lower vehicles there are many mods that have to take place to make everything work right as you are finding out.
My Build: 57 Chevy Pro-Street Last edited by ptc; 06-24-2015 at 03:48 PM. |
06-24-2015, 08:33 PM | #120 |
[QUOTE=lowrodderchev;7219211]any progress?[/QUOTE
Ive done a little more work on the frame! I get some pictures up later or tomorrow! Ive been smoothing out all the seams on the cab for awhile! It takes forever! |
06-24-2015, 08:37 PM | #121 | |
06-27-2015, 10:27 AM | #122 | |
06-30-2015, 12:05 AM | #123 | |
06-30-2015, 01:51 PM | #124 |
nice progress
did you start your build this year or just start posting pics?
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
06-30-2015, 05:38 PM | #125 |
I saw your question in Ogres' thread and answered it there.
Here are some pics on how I did my cowl vent. Kim |
